Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Mass
1 REPLY 1
GelsonD
306 Views, 1 Reply
Mass
I have, maybe a obvious, question. I want to know the weight of a body in Fusion 360. Fusion gives the mass but, do I need to multiply the mass with the acceleration of the earth or it is already done? In English units that is not a problem because of the correction factor but I'm not sure if in International units is different. If some could help me to understand that I would appreciate.
1 REPLY 1
ekinsb
in reply to: GelsonD
The reported mass is the virtual physical weight of the model regardless of whether the results are being reported in lbs, or kg.
Brian Ekins
Mod the Machine blog
