Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
MapBoards / MapBoards Pro not starting
1 REPLY 1
balunist
466 Views, 1 Reply
If you are running an older version of Bommer add-in (before Sept 2019) then either update your version of Bommer or remove.   This older version is preventing Fusion from attempting to start either MapBoards or MapBoards Pro.  The publisher kindly helped in identifying this issue.
Icarus
Labels (1)
1 REPLY 1
balunist
in reply to: balunist
Here is an update on the incompatibility between add-ins MapBoards Pro and Bommer.
It turned out that both add-ins were contributors to the problem and changes from both add-ins will be submitted this week which will cover all possibilities and prevent this issue from recurring.
Icarus
