Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
making a 3D spline using points of existing sketch splines
2 REPLIES 2
franck.gressier
512 Views, 2 Replies
I have been searching to do this in various ways but nothing worked out.
What I want to do:
I have a bunch of sketch splines that I use to create a loft.
As guide rail I would like to make a spline going by point #5 of each of the sketch splines...
xYplane = design.rootComponent.xYConstructionPlane
sketch3dSplines = sketches.add(xYplane)
sketch3dSplines.name ="sketch3dSplines"
SplineRailPoints = adsk.core.ObjectCollection.create()
for loc in sections: # I have a dictionary indexing my sketch Splines
courbe = sketchsProfils[loc].sketchCurves.sketchFittedSplines.item(0)
sketch3dSplines.include(courbe.fitPoints(5))
SplineExPoints.add(sketch3dSplines.points(-1))
SplineEx = sketch3dSplines.sketchCurves.sketchFittedSplines.add(SplineExPoints)
This says that SkechPointList object is not callable... when I try to include the spline fitPoint  5 .
Adding without including isn't better.
I have also tryed to make a list of the points while creating the splines but then I get a curve all messed up in the xY plane and not at all what I expect...
Do I need to add some .geometry in this ?
2 REPLIES 2
I have kept searching.
I can access the 3d coordinates of the points like this:
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
spline = adsk.fusion.SketchFittedSpline.cast(ui.activeSelections.item(0).entity)
if spline:
result = ''
for sketchpoint in spline.fitPoints:
point = sketchpoint.worldGeometry
result += '{}, {}, {}\n'.format(point.x, point.y, point.z)
ui.messageBox('Spline points: {}\n {}'.format(spline.fitPoints.count, result))
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
But that is not really what I want. I would like to reuse the existing points.
I guess I could create new points and merge but it seems heavy.
Sometimes you look for complicate things....
Not callable is because I used "()" which are for functions...
.item(5) is better.
[5] could do I guess
But I get another error:
However, i was able to avercome this with world.geometry...
This works ! :o)
def run(context):
ui = None
try:
design = app.activeProduct
comp = design.activeComponent
#ui.messageBox(comp.name)
sketches = comp.sketches
SplineExPoints = adsk.core.ObjectCollection.create()
for sk in sketches:
spline = sk.sketchCurves.sketchFittedSplines.item(0)
SplineExPoints.add(spline.fitPoints.item(5).worldGeometry)
except:
if ui:
Tags (3)
