Looking for an add-on developer / Addon ideas for you to steal [PAID... or free]
Hello everyone,
I hope this post doesn't go against any rules, the way the rules page is set up and accessed are both equally annoying and make it seem like the rules are not important... They need to fix that
Payments done over PayPal
I am seeking out for add-ons to be developed, and whether they're to be updated over time or not depends on the developer. These add-ons would be paid or free, dev's choice, and I expressly give consent for them to be sold on the Add-ons Store. If one person makes all of these, then I suggest you split them up into different add-ons
STL Exporter
Fusion updates have complicated the way I export models. I have to select the single body I will be exporting, select the type, and then name it because it sets the name to "Body_" and not the file name.
• What I need is an add-on that will tap in to whatever current STL export options there are, and export the visible models as STL(Binary), then automatically take the name from the file.
• I don't like switching menus, opening the add-on control panel, or running scripts. I would like it if the add-on has a right-click context menu for me to quickly export the model.
• I also would like a thing to set what folder I want the models to be dumped to, I have a dedicated Fusion 360 folder on a separate drive and don't want any files on my main drive in case of system failures.
Combine Components
A lot of my files are made from prefabbed files that are dragged in to new canvases as components, and I sometimes have to make a new body to sacrifice to the component gods
• I would like an add-on that allows me to quickly combine components to a solid body for editing
Pivot From Origin Shortcut
All of my work is started from the center of the canvas. I am constantly having to Set Pivot to the Origin whenever I drag new components into the canvas. This is extremely annoying as I click the Set Pivot button and not only have to go all the way across the screen to the other side, but then have to avoid every single object in the canvas otherwise it will set the pivot to random points on models and sketches sometimes even if I've already set the pivot to the center of the canvas...
• Ideally I'd like just a button right next to the Set Pivot button, in the Move Tool panel, but I can work with just a keyboard shortcut or something else as long as it's easy to get to
On Screen Buttons
There are some tools for Windows that are used by digital illustrators and others that add buttons which can be customized. Something like this directly made to match Fusion would be great as I am constantly inputting the same numbers, and I've been made fun of for suggesting the idea of "Set Parameters Per Project".
Thank you for your time,
-Sid
