Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
List of Available methods and objects with usage descriptions for Python
1 REPLY 1
nnamfoh
386 Views, 1 Reply
This may be a simple question but I can't seem to find it.
Usually when I'm working from an existing code base or in a language I'm unfamiliar with there is some API reference page that has lists and lists of objects and functions I have access to and a brief description of what they do. Where can I get this for adsk.core, adsk.fusion, adsk.cam, preferably in Python?
I've found lots of samples but I have no way of searching for existing methods to help build my own add-in.
An example of what I'm looking for is the Java API (https://docs.oracle.com/javase/7/docs/api/) Does anything like this exist for adsk?
1 REPLY 1
KrisKaplan
in reply to: nnamfoh
The API reference is available on the Fusion 360 Learning page at http://fusion360.autodesk.com/learning/learning.html under the 'Programming Interfaces' section in 'Fusion 360 API Reference Manual'.  From Fusion this is available from the 'Help' menu (in the upper right), through the 'Learn Fusion 360' command, which will take you to the 'Getting Started With Fusion 360' page, and you can then use the link on the right to 'See All Fusion 360 learning'.
Kris
Kris Kaplan
