Latest version of the Fusion 360 API Object Model reference PDF?
I this the latest version of the Fusion 360 API Object Model reference chart PDF?
Dated September 21, 2017....
https://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/images/Fusion.pdf
BrianEkins
That is the latest version and it's mostly up to date.  The things missing the chart are the objects that are listed in the  "What's New" of the most recent API documentation.  It's from December 2017, but nothing has been added to the API since then.
Brian Ekins
stephenfinch970
I know this is an old thread, but I would like to know if there is a newer version of the Object Model Reference PDF.
The most recent version I have found is dated September 21, 2017.  And it is obviously out of date.  I was trying to combine two blocks like in the Modify/Combine operation in the ui.  I couldn't find a feature on the Object Model Reference pdf.  I spent a lot of time trying to find out how to do it using other features, none of which worked.  I only stumbled on the CombineFeature objects by accident after examining a lot of examples.   And I know that there are other items not on this pdf as I've found other things via the same search/examine/interpret sequence costing me (sometimes) hours .
For us "new" API users, a more accurate (and reliable) Object Model Reference PDF would be a great help.
Thanks.
OceanHydroAU
Here's an example help document URL:  https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3F3156FF-3125-4118-A8A1-BA5C78621855
You can see the cool new things they've just added indicated by the little "test tube" icons beside them (scroll up and down on the left to see everything).  The search box at the top-right is indispensable!
BrianEkins
I agree that an updated Object Model chart would be very useful. The current one is the latest; hopefully, we'll see an update soon. With all of the recent additions to the API, it will take some work to get it to fit on the page.
Brian Ekins
