Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Latest Fusion 360 Update Resulted in Black Strips at Top and Bottom in Place of the Tool Bar
23 REPLIES 23
Message 1 of 24
tperam
2296 Views, 23 Replies
Latest Fusion 360 Update Resulted in Black Strips at Top and Bottom in Place of the Tool Bar.
Something is wrong.
Pls Fix it.
Thurai
23 REPLIES 23
Message 2 of 24
dsouzasujay
in reply to: tperam
Hi @tperam ,
Could you please attach a screenshot of it?
Edited:
Also Please send the diagnostic files from HERE
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 3 of 24
tperam
in reply to: dsouzasujay
Hi Here is the screenshot
Message 4 of 24
dsouzasujay
in reply to: tperam
Hi @tperam
Can you try a solution provided by @lance.carocci .
In Message 29
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 5 of 24
tperam
in reply to: tperam
Hi I cannot see the Tool bar ? sign to send the diagnostic files.
Thurai
Message 6 of 24
dsouzasujay
in reply to: tperam
Try my last comment for a possible solution.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 7 of 24
tperam
in reply to: tperam
     I followed the steps.
I still have the same issue.
I have Windows 10 Professional.
Thurai
Message 8 of 24
changedsoul
in reply to: tperam
I also ave the problem and I have tried the solution and now get this error when trying to launch fusion after creating the environment variable.
This really blows Fusion. You should have a roll back feature or something for issues like this. My forced update bricked my way to make money.
Message 9 of 24
in reply to: tperam
Same exact issue happened to me today.
Message 10 of 24
in reply to: tperam
I am having the same problem
Message 11 of 24
dsouzasujay
@tperam @changedsoul @Anonymous ,
If above solution is not working.
Please Remove below Environment Variables
  • Variable Name: QT_OPENGL
  • Variable Value: software
And add below Environment Variables.
  • Variable Value: angle
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 12 of 24
tperam
Hi Sujay D'souza,
it works as per your suggestion.
Thurai
Message 13 of 24
vramos678
in reply to: tperam
I'm having the same issue. I tried this fix and it just turned the strip at the top white instead of black.
Message 14 of 24
vramos678
in reply to: vramos678
Just noticed the second fix that uses angle instead of software. It worked.
Message 15 of 24
cekeller9
in reply to: tperam
I too had this black bar problem just after todays update. This is clearly an autodesk bug since it was working perfectly for the last hour before i restarted fusion due to a problem getting a canvas image to load... I am going to wait for autodesk to push the fix out after more of us search for this topic!  Just did a uninstall/re-install cycle and still has the same problem.
Message 16 of 24
cekeller9
in reply to: cekeller9
This actually solution (message 11) fixed the problem - thanks
"And add below Environment Variables.
Variable Value: angle"
Message 17 of 24
tperam
in reply to: tperam
Thanks Everyone.
Environment Variable Fix Worked.
Thurai
Message 18 of 24
in reply to: tperam
Thank you for the fix.
Message 19 of 24
dsouzasujay
Hi @Anonymous @tperam @cekeller9 @vramos678 @Anonymous
The latest Fusion 360 Update has the fix, Build number 2.0.10148.(You may need to restart Fusion 360 to see Auto-Update)
Note: After Fusion 360 updated to build  2.0.10148 version, then you can clear the environment variables.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 20 of 24
thanks, works fine 👌
