Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Keyshot Plugin Broken with Latest Update
0 REPLIES 0
Message 1 of 1
xAragornx
295 Views, 0 Replies
My workflow was majorly disrupted when I went to export my studio walls and other geometry from fusion 360 to Keyshot 6.3.
Ever since the update which occured on Saturday May 7th 2016, the export to keyshot option(s) no longer appear.  Under the "Render" menu. The options are normally in the Render workspace, in the toolbar dropdown section under the render option. Since the format changed, those optioned seemed to be no longer there.
My workflow is stuck until the problem is fixed. Help my Autodesk support staff...you're my only hope
Tags (3)
Labels (1)
0 REPLIES 0
