Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Javascript Fusion 360 API in Visual Studio
1 REPLY 1
richter
432 Views, 1 Reply
Hi guys,
is it possible to develop Javascript addins in Visual Studio with working Intellisense on Fusion API objects? Trying to configure it for some time, but with no success.
Thank you very much!
1 REPLY 1
richter
in reply to: richter
Figured it out finally. Add references to the header of addin js file like this:
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\application.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\dashboard.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\geometry.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\materials.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\core\userInterface.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\bRep.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\components.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\construction.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\features.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\fusion.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\meshBody.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\meshData.js" />
/// <reference path="C:\Users\richt\AppData\Local\Autodesk\webdeploy\production\8761ad41e24127c30f608621af9f94797e223b67\JavaScript\adsk\Fusion\sketch.js" />
