Announcements
Japanese characters do not display on dialogbox.
obatake5TC3R
obatake5TC3R
I am making script by VisualStdio(C++) on windows.
So I made a dialogbox on Fusion360. But japanese chacters not dispay.
Which do I use SIFT-JIS or utf8 code ?
I tested both checters, but not displayed on the dialogbox.
How do I do?
KrisKaplan
The API accepts and returns UTF-8 encoded strings.  For example, the following C++ code can be used to display UTF-8 strings in a message box.
extern "C" XI_EXPORT bool run(const char* context)
	app = Application::get();
	if (!app)
		return false;
	ui = app->userInterface();
	if (!ui)
		return false;
	ui->messageBox(u8"こんにちは", u8"タイトル");
	return true;
Of course, any UTF-8 encoded character string should be fine (not just 'u8' string literals).  If there is a specific API that you see is not behaving this way please post a specific example demonstrating the problem and we will look into it.
Kris
Kris Kaplan
