Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Iterating through ProductPreferencesCollection throws InternalValidationError
1 REPLY 1
krisztian_szaboWCZZ3
74 Views, 1 Reply
I tried iterating through the items in a ProductPreferencesCollection in Python and got a InternalValidationError/RuntimeError as a result.
Minimal code to reproduce the issue:
applicationPreferences = app.preferences
productPreferences = applicationPreferences.productPreferences
for i in range(productPreferences.count):
    logger.info(productPreferences.item(i))
And got the following error:
[EXCEPTION]
2 : InternalValidationError : res
Traceback (most recent call last):
File "<redacted>", line 935, in notify
File "<redacted>/AppData/Local/Autodesk/webdeploy/production/1b7b241a4d7e74709532875784c66d9a6c8030aa/Api/Python/packages\adsk\core.py", line 14755, in item
return _core.ProductPreferencesCollection_item(self, index)
RuntimeError: 2 : InternalValidationError : res
Platform: Windows 11 Pro 22H2 (22621.2283)
Fusion 360 version: 2.0.17244 x86_64
1 REPLY 1
Hi @krisztian_szaboWCZZ3 -San.
I was able to avoid the error by doing it this way instead of using the item method.
# Fusion360API Python script
import traceback
import adsk.core as core
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
            pref = productPreferences[i]
            if not pref:
                print(f"{i}:None")
            else:
                print(f"{i}:{pref.classType()}")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
However, it was almost empty.
0:None
1:None
2:adsk::fusion::FusionProductPreferences
3:None
4:None
5:None
6:None
7:None
8:None
9:None
10:None
11:None
