Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
It's all about time!
4 REPLIES 4
jackie.lin.945
150 Views, 4 Replies
After got Fusion 360 Educational access(2021-12-18), I try to write python script to draw 3D objects.
This drawing is derived from the Alhambra palace pattern.
It need 1m:40s to draw.
In the process of drawing I must make myself believe the script is running.
Because there is nothing on screen to show you that the script is still alive and running.
Sometimes I can see not responding on title bar . . .
But at last the graph result is shown.
I want to know . . .
Is there a way to know my script is running and not dead?
Thank you.
4 REPLIES 4
a
jackie.lin.945 in reply to eromeBriot :
Thank you.
I follow the sample code of progress dialog from the URL that you show me.
It works.
One really need to have confidence in his/her script code.
My Fusion 360 python script runs 7m:41s.
Seeing the progress bar running make me relieved.
Because I know my script is still alive.
Great!
Note that the progress dialog also consumes time : Don't use progress dialog with large data
