Issues with importing .implicit geometry (nTop addon)
DrTea
Observer
DrTea
Observer
Observer
Basically It should be imported like the first picture but instead it is being imported as the second picture  any1 know the fix t o this? also if any1 knows how to keep most of the geometry without needing a supercomputer to render that would be appreciated.
BrianEkins
What file type are you importing? I'm unaware of any file types supported by Fusion that support this type of geometry definition. Fusion does support this type of geometry using the "Volumetric Lattice" command, but I don't think importing or exporting it is supported except if you create a mesh of the lattice and use that.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
