Issues querying coordinates from construction points
en9y37
en9y37
Hi there.
I have defined one construction point within each component in my design by the three planes method.
If I query the coordinates of this construction points using the API Object Explorer, I get the right coordinates if I select the construction points directly from the browser or from the Time Line:
The issues come when I query the coordinates via this object:
component.constructionPoints.itemByName('_O_').geometry
The coordinates I get in this case are these:
I have also tried to get these coordinates through the timeline, and the output is still wrong:
Any idea about what object should I use to get the right coordinates?
en9y37
In order to give more information, I've just noticed that the coordinates issue only happens in those components in which their own coordinates systems don't match the root component origins.
In this case this happens because one component was created by simetry from another.... I'll keep on researching
kandennti
Hi @en9y37 .
Try this.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        msgLst = []
        for occ in root.allOccurrences:
            comp: adsk.fusion.Component = occ.component
            for constPoint in comp.constructionPoints:
                point: adsk.core.Point3D = constPoint.geometry
                point.transformBy(occ.transform2)
                msgLst.extend(
                        f'<< {occ.name} : {constPoint.name} >>',
                        f'ConstructionPoint.geometry : {constPoint.geometry.asArray()}',
                        f'transformBy(occurrence.transform2) : {point.asArray()}\n',
        ui.messageBox('\n'.join(msgLst))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
en9y37
Thanks a lot @kandennti !!!!
That works great. You saved me... again
BenHarper-3Dtek
May I ask, where do you find this "API Object Explorer" !?!
It looks very handy!
