Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Issues on design.modifyParameters method
5 REPLIES 5
en9y37
221 Views, 5 Replies
Hi all.
Recently I'm dealing with the design.modifyParameters method, which is intended to modify several parameters at once more efficiently.
Everything works fine as long as I use it to modify model parameters, but nothing happens if I try to modify user parameters, even the method returns True although there's no a change at all.
Is there any know issue or bug about this? Here I leave a f3d and the code to reproduce this bug.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        para1 = design.allParameters.itemByName('para1')
        para2 = design.allParameters.itemByName('para2')
        parameterList = [para1, para2]
        value1 = adsk.core.ValueInput.createByReal(20)
        value2 = adsk.core.ValueInput.createByReal(20)
        valueList = [value1, value2]
        result = design.modifyParameters(parameterList, valueList)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thanks in advance to all.
5 REPLIES 5
BrianEkins
in reply to: en9y37
I can reproduce the problem and will make sure a bug gets files. I wonder if this is a new problem or if it's always behaved like this.
Brian Ekins
en9y37
in reply to: BrianEkins
Thanks @BrianEkins for your response and for confirming this is a bug
I've never been able to make this method to work properly. I used to think that it was due to some mistake of mine. So perhaps you're right and this method always has behaved like this.
en9y37
in reply to: en9y37
More issues about this.
I've just noticed that if the values list is generated trough the adsk.core.ValueInput.creatreByString() method, the expression is not modified (so far, just tested in model parameters, in user parameters not working yet). Instead of that, just the value is modified following the equation of the expression.
By the way, any new about a fix for this bug?
john.kirchner
in reply to: en9y37
Hello - it looks like there was a fix for this bug that will be included in the next release towards the end of the month I believe. The behavior you described with using ValueInput.createByString() was noticed so that should be accounted for as well.
en9y37
in reply to: john.kirchner
Thanks @john.kirchner !!
Just tested the fix in the insider pre-release and works great.
Thanks all Autodesk team!!!
