Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
isPromoted property
3 REPLIES 3
DonghuiKZ2ET
248 Views, 3 Replies
isPromoted property
Hi
I created a new panel, and add commands to the panel.
I set isPromoted property to true.
The command is on the panel, but its icon is not shown.(Command Icon is shown in panel drop-down menu.)
Could you tell me how to show the icon too?
Thank you.
3 REPLIES 3
liujac
in reply to: DonghuiKZ2ET
I can't reproduce the problem with the addin I attached. Please have a try on this addin to see if it works.
Jack
DonghuiKZ2ET
in reply to: liujac
Thank you for help.
ekinsb
It looks like there's not an icon assigned to the command.  I believe for the promote capability to be enabled the command has to have an icon.
Brian Ekins
Mod the Machine blog
