IsoCurve Script
OrhunUnal
IsoCurve Script
OrhunUnal
Video Player is loading.
Current Time 0:00
Duration 0:00
Loaded: 0%
Stream Type LIVE
Remaining Time 0:00
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
      (view in My Videos)
      I created IsoCurve script using ChatGPT, for now it works only on NURBS surfaces and the number of points of the generated curve is too much due to the number of spans of the surface.
      IsoCurve Script
      import adsk.core, adsk.fusion, adsk.cam, traceback
      def create_isocurve(context):
          ui = None
          try:
              # Get Fusion 360 application and user interface
              app = adsk.core.Application.get()
              ui = app.userInterface
              design = app.activeProduct
              rootComp = design.rootComponent
              sketches = rootComp.sketches
              # Ask user to select a face
              ui.messageBox("Please select a face on the surface.")
              selection = ui.selectEntity("Select a surface face", "Faces")
              selected_face = adsk.fusion.BRepFace.cast(selection.entity)
              if not selected_face:
                  ui.messageBox("No face selected.")
                  return
              # Get the surface geometry of the face
              surface = selected_face.geometry
              if not isinstance(surface, adsk.core.Surface):
                  ui.messageBox("Selected face is not a parametric surface.")
                  return
              # Get the evaluator and parametric range
              evaluator = surface.evaluator
              param_range = evaluator.parametricRange()
              u_min, u_max = param_range.minPoint.x, param_range.maxPoint.x
              v_min, v_max = param_range.minPoint.y, param_range.maxPoint.y
              # Normalize and denormalize functions
              def normalize(value, min_val, max_val):
                  return (value - min_val) / (max_val - min_val) if max_val != min_val else 0.0
              def denormalize(norm_value, min_val, max_val):
                  return norm_value * (max_val - min_val) + min_val
              # Ask user for isocurve parameter
              param_input = ui.inputBox(
                  "Enter the isocurve parameter value (Normalized Range: U: 0.0-1.0 or V: 0.0-1.0):",
                  "Isocurve Parameter",
                  "0.5"
              if not param_input:
                  ui.messageBox("Parameter value is invalid or was canceled.")
                  return
              normalized_parameter = float(param_input[0])  # Fix: Access first element
              # Get user input for U or V direction
              direction_input = ui.inputBox("Enter the direction (u or v):", "Isocurve Direction", "u")
              if not direction_input:
                  ui.messageBox("Direction value is invalid or was canceled.")
                  return
              direction = direction_input[0].lower()
              if direction not in ['u', 'v']:
                  ui.messageBox("Invalid direction. Please enter 'u' or 'v'.")
                  return
              # Convert back to actual U/V parameter range
              if direction == 'u':
                  actual_parameter = denormalize(normalized_parameter, u_min, u_max)
                  degree = surface.degreeU  # Get U direction degree
              else:
                  actual_parameter = denormalize(normalized_parameter, v_min, v_max)
                  degree = surface.degreeV  # Get V direction degree
              if degree is None:
                  ui.messageBox("The selected surface does not have a valid degree for the chosen direction.")
                  return
              # Generate points for the isocurve
              num_points = max(degree + 1, 15)  # Ensure enough points for smooth curve
              start, end = 0.0, 1.0
              t_values = [start + (end - start) * i / (num_points - 1) for i in range(num_points)]
              curve_points = []
              for t in t_values:
                      success, point = evaluator.getPointAtParameter(adsk.core.Point2D.create(actual_parameter, denormalize(t, v_min, v_max)))
                  else:
                      success, point = evaluator.getPointAtParameter(adsk.core.Point2D.create(denormalize(t, u_min, u_max), actual_parameter))
                  if success:
                      curve_points.append(adsk.core.Point3D.create(point.x, point.y, point.z))
                  else:
                      ui.messageBox("Failed to evaluate point at parameter. Ensure the parameter value is valid for the surface.")
                      return
              # Ask user for spline type (shortened input)
              spline_type_input = ui.inputBox("Enter spline type (F for fitted, C for control):", "Spline Type", "f")
              if not spline_type_input:
                  ui.messageBox("Spline type value is invalid or was canceled.")
                  return
              spline_type_short = spline_type_input[0].lower()  # Get the first character
              # Convert short input to full type
              if spline_type_short == "f":
                  spline_type = "fitted"
              elif spline_type_short == "c":
                  spline_type = "control"
              else:
                  ui.messageBox("Invalid input. Using 'fitted' as default.")
              # Create a sketch on the default XY plane
              sketch_plane = rootComp.xYConstructionPlane
              sketch = sketches.add(sketch_plane)
              # Convert curve points to ObjectCollection
              spline_points = adsk.core.ObjectCollection.create()
              for point in curve_points:
                  spline_points.add(point)
              # Convert ObjectCollection to a Python list for control splines
              control_point_list = list(curve_points)  # FIX: No need for .cast()
              # Add spline to the sketch
              if spline_type == "control":
                  sketch.sketchCurves.sketchControlPointSplines.add(control_point_list, degree)  # FIXED
              else:
                  sketch.sketchCurves.sketchFittedSplines.add(spline_points)
              ui.messageBox(f"Isocurve created successfully as a {spline_type} spline.")
          except Exception as e:
              if ui:
                  ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
      create_isocurve(None)
      Also I created script for getting information about surface degree and span count
      def run(context):
          ui = None
          try:
              if not design:
                  ui.messageBox('No active Fusion 360 design.')
                  return
              # Get the current selection
              selected_entities = ui.activeSelections
              if selected_entities.count != 1:
                  ui.messageBox('Please select exactly one surface before running the script.')
                  return
              selected_face = selected_entities.item(0).entity
              # Verify the selected entity is a face
              if not isinstance(selected_face, adsk.fusion.BRepFace):
                  ui.messageBox('The selected entity is not a face.')
                  return
              geom = selected_face.geometry
              # Ensure the selected face is a NURBS surface
              if not isinstance(geom, adsk.core.NurbsSurface):
                  ui.messageBox('The selected face is not a NURBS surface.')
                  return
              # Get degree and span count
              uDegree = geom.degreeU
              vDegree = geom.degreeV
              uControlPoints = geom.controlPointCountU
              vControlPoints = geom.controlPointCountV
              # Calculate span count
              uSpanCount = uControlPoints - uDegree
              vSpanCount = vControlPoints - vDegree
              # Display the results
              msg = f"""Surface Details:
              - U-Direction Degree: {uDegree}
              - V-Direction Degree: {vDegree}
              - U-Direction Control Points: {uControlPoints}
              - V-Direction Control Points: {vControlPoints}
              - U-Direction Span Count: {uSpanCount}
              - V-Direction Span Count: {vSpanCount}"""
              ui.messageBox(msg, 'Surface Degree and Span Count')
              if ui:
                  ui.messageBox(f'Failed: {traceback.format_exc()}')
      Replies (0)
      Type a product name
