Is this something that can be scripted? Automatic filleting of embossed text
drew.porter
drew.porter
I want to fillet embossed text so there are no sharp edges. Currently the process is all manual and can take significant amounts of time selecting the correct edges and then iterating through the values until the fillet is successful.
I would love to have a script that allows me to select the extrude feature for the embossed text and then it iterates through values until the largest fillet possible succeeds. Is that something that can be scripted? I have never written a script, so before I try and learn how to do it i wanted to see if it was even feasible.
Thanks!
The steps that it would need to take are
1. Select all the edges internal to the text (normal to the face it is embossed on)
and fillet to get this
2. Select the edges that are coincident with the face it is embossed on
and fillet for this result
 3. Select all the top surfaces of the text
for a final result like this
jordan783ZS
Could you potentially accomplish this using a "Rule Fillet" on the emboss feature?
https://www.youtube.com/watch?v=1V0P-f41Jns
drew.porter
Unfortunately, not. I was really excited when I learned about rule fillets for this exact use case. However, it does not achieve the desired results as I am not able to specify the correct order of fillets.
kandennti
Hi @drew.porter -San.
It is incomplete, but I made a simple one.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        # select faces
        msg: str = 'Select Top Face(PlanarFaces)'
        selFilter: str = "PlanarFaces"
        sel: core.Selection = select_ent(msg, selFilter)
        if not sel: return
        faceTop: fusion.BRepFace = sel.entity
        msg = 'Select Bottom Face(PlanarFaces)'
        sel = select_ent(msg, selFilter)
        if not sel: return
        faceBottom: fusion.BRepFace = sel.entity
        if not faceTop.body == faceBottom.body:
            ui.messageBox("Select a surface that belongs to the same body!")
            return
        # tokens
        faceTopToken: str = faceTop.entityToken
        faceBottomToken: str = faceBottom.entityToken
        # vertical edges
        edge: fusion.BRepEdge = None
        faces = []
        for edge in faceTop.edges:
            faces.extend(
                [f for f in edge.faces if f != faceTop]
        tmpEdges = [e for f in faces for e in f.edges if e not in faceTop.edges]
        verticalEdges = deleting_duplicates_by_tokens(
            [e for e in tmpEdges if e not in faceBottom.edges]
        comp: fusion.Component = faceTop.body.parentComponent
        filletFeats: fusion.FilletFeatures = comp.features.filletFeatures
        filletFeat: fusion.FilletFeature = None
        filletFeat = try_maximum_rudius(filletFeats, verticalEdges)
        if not filletFeat: return
        #side faces
        sideFaces = []
        face: fusion.BRepFace = None
        for face in filletFeat.faces:
            sideFaces.extend(list(face.tangentiallyConnectedFaces))
        sideFaces = deleting_duplicates_by_tokens(sideFaces)
        # side edges
        sideEdges = []
        for face in sideFaces:
            sideEdges.extend(list(face.edges))
        sideEdges = deleting_duplicates_by_tokens(sideEdges)
        # bottom
        bottomface: fusion.BRepFace = des.findEntityByToken(faceBottomToken)[0]
        targetEdges: list[fusion.BRepEdge] = []
        for edge in bottomface.edges:
            if edge in sideEdges:
                targetEdges.append(edge)
        filletFeat = try_maximum_rudius(filletFeats, targetEdges)
        # top
        topFace: fusion.BRepFace = des.findEntityByToken(faceTopToken)[0]
        filletFeat = try_maximum_rudius(filletFeats, list(topFace.edges))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def try_maximum_rudius(
        filletFeats: fusion.FilletFeatures,
        edges: list,) -> fusion.FilletFeature:
    filletIpt: fusion.FilletEdgeSetInput = filletFeats.createInput()
    filletIpt.isRollingBallCorner = True
    radius1 = core.ValueInput.createByReal(1)
    constRadiusInput: fusion.ConstantRadiusFilletEdgeSetInput = filletIpt.edgeSetInputs.addConstantRadiusEdgeSet(
        core.ObjectCollection.createWithArray(edges),
        radius1,
        True
    constRadiusInput.continuity = fusion.SurfaceContinuityTypes.TangentSurfaceContinuityType
    edgeCount = len(edges)
    left = 0.001  # 最小半径
    right = 1.0  # 最大半径
    best_radius = None
    iteration_limit = 20  # 最大繰り返し回数
    for _ in range(iteration_limit):
        if abs(right - left) < 0.02:  # 収束条件
            break
        mid = round((left + right) / 2, 2)
        constRadiusInput.radius = core.ValueInput.createByReal(mid)
        try:
            filletFeat: fusion.FilletFeature = filletFeats.add(filletIpt)
            if filletFeat.faces.count == edgeCount:
                best_radius = mid
                left = mid  # より大きい値を試す
                filletFeat.deleteMe()
            else:
                right = mid  # faces.countが一致しない場合は小さい値を試す
        except:
            right = mid  # 失敗したら小さい値を試す
    print(_)
    # 最後に見つかった最適な半径で実行
    if best_radius:
        constRadiusInput.radius = core.ValueInput.createByReal(best_radius)
        filletFeat = filletFeats.add(filletIpt)
        return filletFeat
def deleting_duplicates_by_tokens(
        lst: list) -> list:
    itemDict = {}
    item: fusion.BRepEdge = None
    for item in lst:
        token = item.entityToken
        if not token in itemDict:
            itemDict[token] = item
    return list(itemDict.values())
def select_ent(
    msg: str,
    filter: str) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filter)
        return sel
    except:
        return None
drew.porter
Oh that is amazing! Thank you so much!
Would it be possible to modify it to select multiple top faces? Currently it only selects one.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
