Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is there an API for Fusion 360 Extensions, particularly Nesting?
2 REPLIES 2
bernard5BABD
259 Views, 2 Replies
I believe I already know the answer to this one, but I have to ask.
Is there an API for Fusion 360 extensions? Right now, I am mostly focused on Nesting, but it would be useful to know for other extensions as well.
Thanks for your help, and best regards,
Bernard Grosperrin, Retired, Maker, and Autodesk Certified Instructor
Blog : Le Bear CNC | Forum : Le Bear CNC Forum | Addin : Airfoil Sketch from file
2 REPLIES 2
BrianEkins
in reply to: bernard5BABD
Your initial assumption is correct. The API primarily covers the Design functionality, along with partial coverage of CAM capabilities. The only functionality exposed for drawings is the ability to export PDF and there's nothing for Simulation or any of the extensions.
Brian Ekins
bernard5BABD
Thanks for your confirmations, Brian.
