Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is there a way to "request" a validation event?
1 REPLY 1
quality5B59E
214 Views, 1 Reply
I'm trying to control the state of the OK button in a dialog but with a twist.
The dialog represents an item being added to a list and it has a dropdown
to select "item type".  When the user selects different types, other controls
are made visible/invisible in the dialog.  The invisible controls don't matter
for a particular item type so I want to ignore them with regards to validation.
The problem I'm having is that while every time the user changes the dropdown
a *change* event DOES fire,  a *validate* event does not seem to do so?
So I can't control the state of the OK button in response to changing the dropdown?
I could make it work if I "requested" a validation from the change event but I
don't know how to do that (if it's possible).
Am I missing something here?  This is my first add-in after all ... 🙂
Thanks!
1 REPLY 1
quality5B59E
in reply to: quality5B59E
OK ... I found a solution myself.   If you don't want a control to be checked by fusion so the OK button enable/disable state does not depend on it, simply disable the control.
cmdInputs.itemById(CTRL_ID).isEnabled = False
