Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is there a way to get level (position) of component/ assembly from the model tree
1 REPLY 1
pts.user1
110 Views, 1 Reply
I'm trying to fetch the level of component/ assembly from the model tree. Level in terms of how child-parent relationships are linked. For example, the main or root model (car) is at level 1 and the components used might be parts or sub-assembly are there children (engine) which is at level 1.1.
So is there any way to get the value as 1 or 1.1 or any other way?
1 REPLY 1
BrianEkins
in reply to: pts.user1
I'm not exactly sure what you need but you should take a look at this sample.  It traverses the entire assembly and builds an indented list.  It's not numbering them but it easily could.  It is tracking the assembly level so it can indent appropriately.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-5a4fa3a6-fa21-11e4-b610-f8b156d7cd97
Brian Ekins
