Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is there a way to get a CombineFeature for non-parametric?
1 REPLY 1
xapo9966
136 Views, 1 Reply
Dear friends,
I want to create a body by cutting a primary body by another body.  I am using  combineFeature.
According to  the  reference manual  the mehtod combineFeatures.add - "Returns the newly created CombineFeature object or null if the creation failed. This function returns nothing in the case where the feature is non-parametric."
It means that if I turn the history capture off  by setting the designType to
adsk.fusion.DesignTypes.DirectDesignType.
I do not have access to the result. The object has been created within Fusion but I can't get the reference to it. This is very unlucky feature of the API.
Or is there a way how to get the feature object or direct the resulting body?
thank you
Chris
1 REPLY 1
xapo9966
in reply to: xapo9966
huh,
found the answer in a meantime
the combineFeature doesn't exist (not stored in the history)
the final body is the primary body, this is what I need
sorry
chris
