Is there a way to extrude with stored shapes and lines?
matthewaudio
matthewaudio
is there a way to only extrude rectangle A given the following variables?  All the code examples have a stage where they search the sketch items to make a profile.  I already have the sketch items I want to create a profile from
tltrA = mySketch.sketchCurves.sketchLines.addByTwoPoints(tlA, trA)
tlblA = mySketch.sketchCurves.sketchLines.addByTwoPoints(tlA, blA)
trbrA = mySketch.sketchCurves.sketchLines.addByTwoPoints(trA, brA)
blbrA = mySketch.sketchCurves.sketchLines.addByTwoPoints(blA, brA)
tltrB = mySketch.sketchCurves.sketchLines.addByTwoPoints(tlB, trB)
tlblB = mySketch.sketchCurves.sketchLines.addByTwoPoints(tlB, blB)
trbrB = mySketch.sketchCurves.sketchLines.addByTwoPoints(trB, brB)
blbrB = mySketch.sketchCurves.sketchLines.addByTwoPoints(blB, brB)
kandennti
Hi @matthewaudio -San.
It is possible that you have the wrong meaning.
I tried to find a profile with the specified line.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        tlA: core.Point3D = core.Point3D.create(1,2,0)
        trA: core.Point3D = core.Point3D.create(3,2,0)
        blA: core.Point3D = core.Point3D.create(1,-2,0)
        brA: core.Point3D = core.Point3D.create(3,-2,0)
        tlB: core.Point3D = core.Point3D.create(5,2,0)
        trB: core.Point3D = core.Point3D.create(7,2,0)
        blB: core.Point3D = core.Point3D.create(5,-2,0)
        brB: core.Point3D = core.Point3D.create(7,-2,0)
        mySketch: fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
        prof: fusion.Profile = find_profile_with_line(mySketch, tltrA)
        if not prof: return
        extrudeFeats: fusion.ExtrudeFeatures = root.features.extrudeFeatures
        extrudeFeats.addSimple(
            prof,
            core.ValueInput.createByReal(1),
            fusion.FeatureOperations.NewBodyFeatureOperation
        mySketch.isLightBulbOn = True
        ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
def find_profile_with_line(
    skt: fusion.Sketch,
    sktCrv: fusion.SketchCurve,
) -> fusion.Profile:
    if skt.profiles.count < 1: return None
    prof: fusion.Profile = None
    loop: fusion.ProfileLoop = None
    crv: fusion.ProfileCurve = None
    for prof in skt.profiles:
        for loop in prof.profileLoops:
            for crv in loop.profileCurves:
                if crv.geometry.isColinearTo(sktCrv.geometry):
                    return prof
    return None
