Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is there a REST API either for accessing user files or running Fusion code server side?
1 REPLY 1
marcosscriven
242 Views, 1 Reply
There's two things I'm wondering if we can do:
1. Be able to integrate with a user's Autodesk Home to access their files via some oauth or other token based sytem?
2. Be able to run Fusion 360 or add-in functionality on a server (either Autodesk's, or via some library on one's own server)? I've heard of something called 'Forge', but it doesn't quite seem to be the thing I'm looking for.
1 REPLY 1
BrianEkins
in reply to: marcosscriven
You should look at the Forge Data Management API for accessing files.  It's not currently possible to run any Fusion code on the server.
Brian Ekins
