Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
my current solution is to hook up to camera changed event and then on each event go through all named views and compare their camera parameters (eye, target, up_Vector) with the current view camera. It is very hacky and generates multiple events. All doable, but I thought maybe there was a more elegant way.
Hi @soswow -San.
Fusion360 executes commands for many operations.
The UserInterface.commandStarting event is fired when a command is executed.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-EBB6C82A-A256-4AB7-9A86-0F7A9653A7E9
By using the UserInterface.activeCommand property, the ID of the command being executed can be known.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-635C6C94-BA41-44D6-A97D-61BFA56C6688
If you click here, “RestoreCameraCommand” is executing.
@kandennti -San,
Thank you! How do I know which of named views was clicked though? I've looked through
It's ok. I've seen some of your other answers for similar question and it sounds like there is no way to get input information for command this way. I guess that just means I can't use named views as an input for my purposes.
I'd find another way.
@soswow -San.
After the command occurs, we created a sample that compares the current Camera with the Camera in the NamedView and determines that the one that matches is the one that was clicked.
#FusionAPI_python addin
import traceback
import adsk.core as core
import adsk.fusion as fusion
_app = core.Application.cast(None)
_ui = core.UserInterface.cast(None)
_handlers = []
_cmdInfo = {
"id": "kantoku_DumpPickNamedViewTest",
"name": "DumpPickNamedViewTest",
"tooltip": "DumpPickNamedViewTest",
"workSpace": "FusionSolidEnvironment",
"panelId": "SolidScriptsAddinsPanel",
def run(context):
ui = None
try:
global _app, _ui
_app = core.Application.get()
_ui = _app.userInterface
cmdDefs: core.CommandDefinitions = _ui.commandDefinitions
global _cmdInfo
cmdDef: core.CommandDefinition = cmdDefs.itemById(_cmdInfo["id"])
if cmdDef:
cmdDef.deleteMe()
cmdDef = cmdDefs.addButtonDefinition(
_cmdInfo["id"],
_cmdInfo["name"],
_cmdInfo["tooltip"])
global _handlers
onCommandCreated = CommandCreatedHandler()
cmdDef.commandCreated.add(onCommandCreated)
_handlers.append(onCommandCreated)
workSpace: core.Workspace = _ui.workspaces.itemById(_cmdInfo["workSpace"])
targetpanel :core.ToolbarPanel = workSpace.toolbarPanels.itemById(_cmdInfo["panelId"])
controls :core.ToolbarControls = targetpanel.controls
cmdControl :core.ToolbarPanel = controls.addCommand(cmdDef)
cmdControl.isVisible = True
except:
if _ui:
_ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
class CommandCreatedHandler(core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
try:
global _app, _ui, _handlers
cmd = core.Command.cast(args.command)
des :fusion.Design = _app.activeDocument
core.Camera.isEqual = isEqual
# event
onCommandTerminated = MyCommandTerminatedHandler()
_ui.commandTerminated.add(onCommandTerminated)
_handlers.append(onCommandTerminated)
except:
if _ui:
class MyCommandTerminatedHandler(core.ApplicationCommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.ApplicationCommandEventArgs):
if not _ui.activeCommand == "RestoreCameraCommand": return
stateCam: core.Camera = _app.activeViewport.camera
des: fusion.Design = _app.activeProduct
views: core.NamedViews = des.namedViews
view: core.NamedView = None
for view in views:
if stateCam.isEqual(view.camera):
_app.log(f"Pick NamedView {view.name}!!")
return
def isEqual(self: core.Camera, cam: core.Camera) -> bool:
if not self.cameraType == cam.cameraType:
return False
if not self.eye.isEqualTo(cam.eye):
return False
if not self.target.isEqualTo(cam.target):
return False
if not self.upVector.isEqualTo(cam.upVector):
return False
if abs(self.perspectiveAngle - cam.perspectiveAngle) > 0.001:
return False
return True
def stop(context):
try:
global _cmdInfo
panel: core.ToolbarPanel = workSpace.toolbarPanels.itemById(_cmdInfo["panelId"])
if panel:
panel.controls.itemById(_cmdInfo["id"]).deleteMe()
if cmdDef:
cmdDef.deleteMe()
except:
print("Failed:\n{}".format(traceback.format_exc()))
Since Design.namedViews contains only the NamedViews that you have created yourself, if you need to detect the use of the default one, you should check the Camera data in advance.
oh yes! Smart people think alike I suppose 😃 I've come up with the same thing. Actually, I found even nicer solution for my case.
Basically, I decided not to worry about named views entirely. Through naming convention and way to detect when canvas is turned on and off, I can move the camera to the required frame, since I have all cameras information when user selects specific convas. And also I hide canvas when camera is moved away.
