Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is it safe to have only a CommandCreated handler?
1 REPLY 1
quality5B59E
214 Views, 1 Reply
Is it safe to do things in the CommandCreated handler instead of installing
an Execute handler and doing it there?   I imagine the transaction stuff gets
bypassed but for simple things is it safe?
class HomePoseCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
# do simple command here instead of installing Execute handler move_to_home_pose()
1 REPLY 1
goyals
in reply to: quality5B59E
I do not think it is mandatory to have a commandExecuteHandler. Please take a look at this example http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-e5c4dbe8-ee48-11e4-9823-f8b156d7cd97 but as you already mentioned the things done as part of command would not be persisted.
Shyam Goyal
Sr. Software Dev. Manager
