Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is it possible to save an already designed sketch/body as python script?
3 REPLIES 3
kleeblättchen
567 Views, 3 Replies
I would like to know if it is possible to generate a Python script out of an already existing body in the design environment.
Many thanks for your help,
Janina
Tags (1)
3 REPLIES 3
adam.nagy
in reply to: kleeblättchen
Hi Janina,
Are you looking for something like recording your steps as a script that cold be run again?
Something like what is available in e.g. Excel?
https://support.office.com/en-gb/article/Automate-tasks-with-the-Macro-Recorder-974ef220-f716-4e01-b...
Unfortunately, that is not available in Fusion.
Maybe you could e.g. save the sketch as DXF (Sketch.saveAsDXF) and reuse it in other design by inserting it.
Cheers,
Adam Nagy
Autodesk Platform Services
ekinsb
Hi Janina,
I'll echo what Adam said about Fusion not currently supporting a record capability to create scripts.  However, what you suggested is different in that you said that you have an existing model and want to create a script that will re-create the model.  There isn't anything currently to do this but for most models this is technically possible and someone in the community could create a program to do this using the existing API.  I don't know that anyone is thinking about or working on this but it would certainly be an interesting project.
Brian Ekins
Mod the Machine blog
kleeblättchen
in reply to: ekinsb
Thank you very much for your help !
