Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
InternalValidationError of Occurrence deleteMe
1 REPLY 1
FabisFusionTutorials
269 Views, 1 Reply
What my script does so far:
- Insert a Component from File (has a jointOrigin)
- Duplicates the inserted Component with
occurence = rootComp.occurrences.addExistingComponent(sourceComponent, adsk.core.Matrix3D.create())
- gets a Occurence and takes the jointOrigin of the imported component
- uses createForAssemblyContext(occurence) to get the jointOrigin of the Copy
jointInput = joints.createInput(occurence.component.allJointOrigins[jointOriginIndex].createForAssemblyContext(occurence), secondJoinOrigin)
- create a joint
- add the occurence to my global array of occurences
what I try to do:
- iterate through my global variable occurences
- delete all occurence of the created copies who were joined:
    for occurence in occurences:
        if occurence.isValid and occurence.component.name == sourceComponent.name:
            occurences.remove(occurence)
            occurence.deleteMe()
- create new occurences and joints for each selected jointOrigin
the first times it works as expected and after selecting the 4th jointOrigin I get this error:
InternalValidationError findObjectPath(this, objPath)
How can i delete the occurences on a save way and prevent the Error?
1 REPLY 1
Solution:
- Iterate over a copy of the occurences
    for occurence in list(occurences):
            #occurence.isLightBulbOn = False
