Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
insert occurrences directly from the ID string.
2 REPLIES 2
maeokaQ2NB3
205 Views, 2 Replies
Hi.
I want to insert occurrences directly from the ID string.
Now,I insert occurrences by FolderName&FileName  with For loop, but very slow for me.
Almost all of the same files are inserted, so I would like to access them directly with the ID in the list. Please tell me how to write dataFile.
addByInsert(dataFile, transform, isReferencedComponent)
dataFile value
<adsk.fusion.Occurrence; proxy of <Swig Object of type 'std::vector< adsk::core::Ptr< adsk::fusion::Occurrence > >::value_type *' at 0x0000019B01BAXXXX> >
2 REPLIES 2
goyals
in reply to: maeokaQ2NB3
Unfortunately you can not create datafile object on fly using ID at the moment and you need to iterate through data folders only to get it.
Shyam Goyal
Sr. Software Dev. Manager
maeokaQ2NB3
in reply to: goyals
We will do it the same way as before.
