I would like to position loaded components from the hard drive
I create a document, then a sketch with a base point.
I create a position list
I constrain my point of the list to that of the base point
I call the component file, here AA.f3d
And I have the error when I want to constrain the component "AA" to the different points.
My script below.
Can you help me please, thanks
My greetings
import adsk.core, adsk.fusion, traceback
import os.path
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
importManager = app.importManager
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
design = app.activeProduct
# Get the root component of the active design.
rootComp = design.rootComponent
newOccs = rootComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
objectA = newOccs.component
# Create a new sketch on the xy plane.
Esquisses = objectA.sketches
xZPlane = objectA.xZConstructionPlane
sketch = Esquisses.add(xZPlane)
# Get sketch health state
health = sketch.healthState
if health == adsk.fusion.FeatureHealthStates.ErrorFeatureHealthState or health == adsk.fusion.FeatureHealthStates.WarningFeatureHealthState:
msg = sketch.errorOrWarningMessage
EsqPoint = sketch.sketchPoints
# Point de base
pointOrigin = adsk.core.Point3D.create(1.8, 0, 0)
recPointO = EsqPoint.add(pointOrigin)
TablChr =[80,480,880,1280] #Position list
Max = len(TablChr)
Inc = 0
while Inc < Max:
iX = pointOrigin.x
iY = float(TablChr[Inc]/10)
iZ = 0.0
point = adsk.core.Point3D.create(iX,iY,iZ)
recPoint = EsqPoint.add(point)
sketch.geometricConstraints.addVerticalPoints(recPointO, recPoint)
sketch.sketchDimensions.addDistanceDimension (recPointO, recPoint,
adsk.fusion.DimensionOrientations.VerticalDimensionOrientation,
adsk.core.Point3D.create (-2,recPoint.geometry.y-8, 0));
fileNameCharniere = 'F:\AA.f3d' #File to open and to position
archiveOptions = importManager.createFusionArchiveImportOptions(fileNameCharniere)
importManager.importToTarget(archiveOptions, objectA)
occ = objectA.occurrences.item(objectA.occurrences.count-1)
cmp = occ.component
Circle = RetourneCurves(cmp)
geo0 = adsk.fusion.JointGeometry.createByPoint(recPoint)
geo1 = adsk.fusion.jointGeometry.createByCurve(Circle, adsk.fusion.JointKeyPointTypes.CenterKeyPoint)
joints = objectA.joints
jointInput = joints.createInput(geo0, geo1)
jointInput.isFlipped = True
jointInput.setAsRigidJointMotion()
joint = joints.add(jointInput)
Inc +=1
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def RetourneCurves(Cmp):
try:
CmpEsqs = Cmp.sketches #retourne collection stretch
Esq = CmpEsqs.item(0) #retourne 1e 1er élément stretch
Cirs = Esq.sketchCurves.sketchCircles #retourne collection de circles
Cir= Cirs.item(0)
return Cir
except:
global ui
if ui:
