Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
InputEventChangedHandler prevents data input on other command input IDs
2 REPLIES 2
Six1Seven1
207 Views, 2 Replies
Hi, back again... (my apologies),
So, I added an InputChangedEvent handler to my program. The reason for this is to detect a checkbox. If checkbox is true, then another value input will expose itself.
Before this checkbox, there are 3 value input commands that execute the creation of a box based on their input dimensions. The problem I am experiencing is that when adding this new InputChangedEvent handler, it prevents the execution of my def drawBox function. (the program just idles and does nothing on execution). Its as if it is waiting for a change in the checkbox (inputchangedevent).
Now, i'm actually thinking it has to do with one specific line in my inputChangedEvent handler, which is...
inputs = eventArgs.firingEvent.sender.commandInputs
i'm not sure. Any help is greatly appreciated. Here is the rest of my code:
import adsk.core, adsk.fusion, adsk.cam, traceback
# Global list to keep all event handlers in scope.
# This is only needed with Python.
handlers = []
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get the CommandDefinitions collection.
        cmdDefs = ui.commandDefinitions
        # Create a button command definition.
        buttonSample = cmdDefs.addButtonDefinition('MainButton','BM Addin Pro', 'This is an Addin for generating boxes','./Resources/Main Icons')
        # Connect to the command created event.
        MainButtonEvent = SampleCommandCreatedEventHandler()
        buttonSample.commandCreated.add(MainButtonEvent)
        handlers.append(MainButtonEvent)
        # Get the ADD-INS panel in the model workspace.
        addInsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        # Add the button to the bottom of the panel.
        buttonControl = addInsPanel.controls.addCommand(buttonSample)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler for the commandCreated event.
class SampleCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
            # Get the command
            cmd = eventArgs.command
            # Get the CommandInputs collection to create new command inputs.
            inputs = cmd.commandInputs
            #Add image input
            imageinput1 = inputs.addImageCommandInput('imageinput1','Diagram:','./Resources/Image Input/image main.png')
            # Create the value inputs
            length_in = inputs.addValueInput('length_in', 'Length','', adsk.core.ValueInput.createByReal(3))
            width_in = inputs.addValueInput('width_in','Width','',adsk.core.ValueInput.createByReal(2))
            thick_in = inputs.addValueInput('thick_in','Thickness','',adsk.core.ValueInput.createByReal(1))
            fillet_cb = inputs.addBoolValueInput('fillet_cb','Add Fillets', True,'', True)
            fillet_in = inputs.addValueInput('fillet_in','Fillet Radius','',adsk.core.ValueInput.createByReal(0))
            onExecute = SampleCommandExecuteHandler()
            cmd.execute.add(onExecute)
            handlers.append(onExecute)
            onInputChanged = inputChangedEvent()
            cmd.inputChanged.add(onInputChanged)
            handlers.append(onInputChanged)
        except:
            if ui:
# Event handler for the execute event.
class SampleCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.CommandEventArgs.cast(args)
            # Code to react to the event.
            ui.messageBox('In command execute event handler.')
            # Get the values from the command inputs.
            inputs = eventArgs.command.commandInputs
            length = inputs.itemById('length_in').value
            width = inputs.itemById('width_in').value
            thickness = inputs.itemById('thick_in').value
            #call drawBox function and add input values
            drawBox(length, width, thickness)
            #call addFillets function and add input value
        except:
            if ui:
def drawBox(length_in, width_in, thick_in): #these values are item IDs - not variables (see above)
    try:
        # Get the active sketch.
        sketch = adsk.fusion.Sketch.cast(app.activeEditObject)
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        act = app.activeProduct
        # Get the root component of the active design.
        rootComp = act.rootComponent
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch1 = sketches.add(xyPlane)
        # Load the lines collection and draw geometry for BOX sketch (division for center around origin)
        Load_lines = sketch1.sketchCurves.sketchLines        #load the line API
        L1 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/-2), (width_in/-2), 0), adsk.core.Point3D.create((length_in/2),(width_in/-2), 0))
        L2 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/2),(width_in/-2),0), adsk.core.Point3D.create((length_in/2),(width_in/2),0))
        L3 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/2),(width_in/2),0), adsk.core.Point3D.create((length_in/-2),(width_in/2),0))                 #draw lines (start, end)
        L4 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/-2),(width_in/2),0), adsk.core.Point3D.create((length_in/-2),(width_in/-2),0))
        #get sketch profile
        prof1 = sketch1.profiles.item(0)
        #Extrude thickness
        extrude1 = rootComp.features.extrudeFeatures
        extrude1_prof = extrude1.createInput(prof1,adsk.fusion.FeatureOperations.NewComponentFeatureOperation)
        distance = adsk.core.ValueInput.createByReal(thick_in)
        extrude1_prof.setDistanceExtent(False, distance)
        finish_extrude1 = extrude1.add(extrude1_prof)    #executes the extrusion
    except:
        if ui:
class inputChangedEvent(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            changedInput = eventArgs.input
            if changedInput.id == 'fillet_cb':
                fillet_in = inputs.itemById('fillet_in')
            # Change the visibility of the scale value input.
            if changedInput.value == True:
                fillet_in.isVisible = True
            else:
                fillet_in.isVisible = False
        except:
            if ui:
def stop(context):
    try:
        # Clean up the UI.
        cmdDef = ui.commandDefinitions.itemById('MainButton')
        if cmdDef:
            cmdDef.deleteMe()
        addinsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl = addinsPanel.controls.itemById('MainButton')
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
2 REPLIES 2
marshaltu
in reply to: Six1Seven1
It looked there was a minor error in your codes. It worked well after I corrected it.
Marshal
    def __init__(self):
        super().__init__()
        try:
            fillet_in = None
            if fillet_in:
                else:
        except:
            if ui:
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
Six1Seven1
in reply to: marshaltu
Marshal,
Thank you! Your solution worked great.
