Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Incorrect propertiesU and propertiesV from NurbsSurface.getData
3 REPLIES 3
CADacombs
233 Views, 3 Replies
Using the code below and the attached model, the values of NurbsSurface.propertiesU and NurbsSurface.propertiesV appear correct, but the two integers corresponding with these properties returned from NurbsSurface.getData() are sometimes not.  For example, a non-rational surface that is periodic along U and open along V is reported as:
NurbsSurface.propertiesU: 6
NurbsSurface.propertiesV: 1
propertiesU from getData: 4
propertiesV from getData: 4
import adsk.core, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        ent = ui.selectEntity("Select a face", "Faces")
        if not (isinstance(ent.entity.geometry, adsk.core.Surface)): return
        surface = ent.entity.geometry
        if surface.surfaceType != adsk.core.SurfaceTypes.NurbsSurfaceType:
            print("Not a NurbsSurface.")
            return
        ns = surface
        print("NurbsSurface.propertiesU: {}".format(ns.propertiesU))
        print("NurbsSurface.propertiesV: {}".format(ns.propertiesV))
        rc = ns.getData()
        if not rc[0]: return
            propertiesU,
            propertiesV,
            ) = rc[-2:]
        print("propertiesU from getData: {}".format(propertiesU))
        print("propertiesV from getData: {}".format(propertiesV))
        #print(rc)
    except:
        if ui:
            sError = 'Failed:\n{}'.format(traceback.format_exc())
            print(sError)
            ui.messageBox(sError)
Thank you
Labels (1)
3 REPLIES 3
kandennti
in reply to: CADacombs
Hi @CADacombs .
I don't know why I can't get the correct information, but it seems that I can use SurfaceEvaluator to get the correct information.
I think the four red marks are the problem, please compare with the result using SurfaceEvaluator.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app.log(u'TextCommandWindow.Clear')
        while(True):
            sel = selectEnt("Select a face", "Faces")
            if not sel:
                break
            if not (isinstance(sel.entity.geometry, adsk.core.Surface)): return
            surface = sel.entity.geometry
                continue
            ns = surface
            app.log('---')
            app.log("NurbsSurface.propertiesU: {}".format(ns.propertiesU))
            app.log("NurbsSurface.propertiesV: {}".format(ns.propertiesV))
            rc = ns.getData()
                propertiesU,
                propertiesV,
                ) = rc[-2:]
            app.log("propertiesU from getData: {}".format(propertiesU))
            app.log("propertiesV from getData: {}".format(propertiesV))
            periodicityU, periodicityV= isPeriodicityUV(sel.entity)
            app.log(f"propertiesU from Evaluator: {periodicityU}")
            app.log(f"propertiesV from Evaluator: {periodicityV}")
    except:
        if ui:
            print(sError)
# https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-d6b7d30a-972b-4117-9292-c0a87be8ba62
def isPeriodicityUV(face: adsk.fusion.BRepFace):
    eva: adsk.core.SurfaceEvaluator = face.evaluator
    _, periodicityU, periodicityV, _, _, _ = eva.getParamAnomaly()
    isPeriodicityU = True if periodicityU[0] != 0 else False
    isPeriodicityV = True if periodicityV[0] != 0 else False
    return isPeriodicityU, isPeriodicityV
def selectEnt(
        msg: str,
        filtterStr: str) -> adsk.core.Selection:
    try:
        sel = ui.selectEntity(msg, filtterStr)
        return sel
    except:
        return None
CADacombs
in reply to: kandennti
Not only for Periodicity of some surfaces, some of the Open and Closed values are also incorrect.  Below is a list of properties comparisons of all the closed surfaces in the provided model.  (Properties of the open surfaces are correct.)  The mismatched values are marked.
The workaround is to avoid using propertiesU and propertiesV from NurbsSurface.getdata.
                NurbsSurface.propertiesU, NurbsSurface.getData()[9]
                               NurbsSurface.propertiesV, NurbsSurface.getData()[10]
 Open:          F, F           T, F <--
 Closed:        T, T           F, T <--
 Periodic:      F, F           F, F
 Rational:      F, F           F, F
 Open:          F, F           T, F <--
 Periodic:      F, F           F, F
 Rational:      T, T           T, T
 Open:          F, F           T, F <--
 Closed:        T, F <--       F, F
 Periodic:      T, T           F, T <--
 Rational:      F, F           F, F
 Open:          F, F           T, F <--
 Rational:      T, T           T, T
 Open:          T, T           F, T <--
 Closed:        F, F           T, F <--
 Periodic:      F, F           F, F
 Rational:      F, F           F, F
 Open:          T, T           F, T <--
 Periodic:      F, F           F, F
 Rational:      T, T           T, T
 Open:          T, T           F, T <--
 Periodic:      F, F           T, F <--
 Rational:      F, F           F, F
 Open:          T, T           F, T <--
 Rational:      T, T           T, T
def comparisonString(
    enum_to_check: int,
    enum_from_prop: int,
    enum_from_method: int) -> str:
    bP = bool(enum_to_check & enum_from_prop)
    bM = bool(enum_to_check & enum_from_method)
    return "{}, {} {}".format(
        str(bP)[0], str(bM)[0], "<--" if bM != bP else "   ")
def run(context):
    ui = None
    try:
        app = adsk.core.Application.cast(app)
        app.log("{:<15}{:<15}".format(
            "NurbsSurface.propertiesU, NurbsSurface.getData()[9]"))
        app.log("{:>30}{}".format(
            "NurbsSurface.propertiesV, NurbsSurface.getData()[10]"))
        while True:
            try:
                sel = ui.selectEntity("Select a face", "Faces")
            except:
                break
            face = adsk.fusion.BRepFace.cast(sel.entity)
            if not (isinstance(face.geometry, adsk.core.Surface)): return
            surface = face.geometry
                app.log("Not a NurbsSurface.")
                return
            ns = adsk.core.NurbsSurface.cast(surface)
            propertiesU = ns.propertiesU
            propertiesV = ns.propertiesV
            nsp = adsk.core.NurbsSurfaceProperties
            getData = ns.getData()
            app.log(" ")
            s = "{:<15}{:<15}{:<15}".format(
                "Open:",
                comparisonString(
                    nsp.OpenNurbsSurface, ns.propertiesU, getData[9]),
                comparisonString(
                    nsp.OpenNurbsSurface, ns.propertiesV, getData[10]))
            app.log(s)
                "Closed:",
                comparisonString(
                    nsp.ClosedNurbsSurface, ns.propertiesU, getData[9]),
                comparisonString(
                    nsp.ClosedNurbsSurface, ns.propertiesV, getData[10]))
            app.log(s)
                "Periodic:",
                comparisonString(
                    nsp.PeriodicNurbsSurface, ns.propertiesU, getData[9]),
                comparisonString(
                    nsp.PeriodicNurbsSurface, ns.propertiesV, getData[10]))
            app.log(s)
                "Rational:",
                comparisonString(
                    nsp.RationalNurbsSurface, ns.propertiesU, getData[9]),
                comparisonString(
                    nsp.RationalNurbsSurface, ns.propertiesV, getData[10]))
            app.log(s)
        app.log("\nEnd of script.")
    except:
        if ui:
            app.log(sError)
Thanks for reporting this. Sorry it took a while to respond.
Logged as FUS-138770.
Also reported more recently here.
