Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Imported spline from CSV won't work
1 REPLY 1
211 Views, 1 Reply
Hi all,
I am trying to import a spline data (co-ordinate data) from excel to Fusion360. I've been able to successfully perform this task numerous time before in my MAC laptop for both .DAT and .CSV file type. However, when I'm trying to do it in my recently purchased Window based laptop, the spline did not appear in the sketch. The data points were there but I have to manually connect each of the dots altogether in order to create modifiable area (i.e. extrude) which can be time consuming in the long run.
Any ideas on this issues?
Tags (3)
1 REPLY 1
JeromeBriot
Which add-in do you use to import the data in Fusion 360?
Can you share a sample CSV file?
