Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Import via hyperlink into fusion 360 iges files or other files a currepted
2 REPLIES 2
my.personal.gtd.cad
211 Views, 2 Replies
Hi there,
i trie to build a database with Parts in this database there are the costs of the Parts.
Now when i Try to import the file via hyperlink API Reference
"fusion360://command=insert&file=Path.f3d" the file doesnt import it, it was working  awhile but since a came from holiday it doesent work no more. i Haven't change the code in my Application.
Anyone a Idea thanks for all answers
2 REPLIES 2
Please give a try if "OpenFileFromWeb" sample addin works for you in your machine. I would like to know if it is dataset-specific issue or not.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
Hi thanks for the quick response,
now it works it was my mistake in the programming code of excel after 30*10^3 coffee cups i was realising that i ned to put a Forward slash in the code daaaaam. it works perfect it wasn't a mistake of autodesk its my mistake.
great product Autodesk
greetings from Germany
thanks
Marshal
