Import file from Project Files into current document
ebunn3
ebunn3
Is there a way to import an existing file from one of your Project Folders into the currently open document.  I see that there is one called "importToTarget2" that allows you to import something that is local to your computer.  Can this be setup to access your Project Files?
Eric
kandennti
Hi @ebunn3 .
Do you mean importing the Data Panel documentation?
Once you have saved the document, make it active and run the script.
The documents in the same folder will be imported as occurrence.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        # get active datafile
        actDataFile: adsk.core.DataFile = app.activeDocument.dataFile
        if not actDataFile:
            ui.messageBox('Save the document once.')
            return
        # get datafile ID
        actId = app.activeDocument.dataFile.id
        # get the unique data file
        dataFolder: adsk.core.DataFolder = app.activeDocument.dataFile.parentFolder
        targetDatafile: adsk.core.DataFile = None
        dataFiles = dataFolder.dataFiles.asArray()
        for df in dataFiles:
            if df.id != actId and df.fileExtension == 'f3d':
                targetDatafile = df
                break
        if not targetDatafile:
            ui.messageBox('Could not find the data file to import.')
            return
        # import datafile
        # https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-D2921ADB-3556-4B9E-98ED-2598EDDB852A
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        root.occurrences.addByInsert(
            targetDatafile,
            adsk.core.Matrix3D.create(),
            False  # True <- with a link
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
ebunn3
@kandennti
I would like to browse for the file, select the one I want to insert and insert it.  I do see a function in there called addByInsert that accomplishes the actual insert into the open file.  Is there a way to browse for a file first?  Can one use ui.createFileDialog to browse for the file first?
I'm trying to mimic this:
Eric
kandennti
@ebunn3 .
Probably, UserInterface.createFileDialog can only be used for local files.
The only thing I can think of is to use TableCommandInput to display a list of files and let the user select one.
https://help.autodesk.com/view/fusion360/ENU/?guid#TableCommandInput
This is a meaningless sample, but it uses TableCommandInput to display the file names in the root folder of the active data panel.
import traceback
import adsk.fusion
import adsk.core
_app = None
_ui = None
_handlers = []
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            global _handlers
            cmd = adsk.core.Command.cast(args.command)
            inputs = cmd.commandInputs
            # event
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            # get activeProject.rootFolder.dataFiles
            actDataFiles: adsk.core.DataFiles = app.data.activeProject.rootFolder.dataFiles.asArray()
            # Table
            rowCount = len(actDataFiles)
            tblStyle = adsk.core.TablePresentationStyles
            tbl = inputs.addTableCommandInput('table', 'Table', 0, '1:10')
            tbl.hasGrid = False
            tbl.tablePresentationStyle = tblStyle.itemBorderTablePresentationStyle
            if rowCount > 10:
                tbl.maximumVisibleRows = 10
            elif rowCount > 4:
                tbl.maximumVisibleRows = rowCount
            for idx, dataFile in enumerate(actDataFiles):
                # check box
                chk = inputs.addBoolValueInput(
                    f'check{idx}',
                    'Checkbox',
                    True,
                    False)
                tbl.addCommandInput(chk, idx, 0)
                # datafile name
                dataName = inputs.addStringValueInput(
                    f'dataName{idx}',
                    'DataName',
                    dataFile.name)
                dataName.isReadOnly = True
                tbl.addCommandInput(dataName, idx, 1)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        global _ui
        cmdDef: adsk.core.CommandDefinition = _ui.commandDefinitions.itemById(
            'Test')
        if cmdDef:
            cmdDef.deleteMe()
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef = _ui.commandDefinitions.itemById('Test')
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = _ui.commandDefinitions.addButtonDefinition(
            'Test', 'Test', 'Test')
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
I think it would be a good idea to create a mechanism so that when the OK button is pressed, only those files whose checkboxes are checked will be processed.
I don't understand it because I've never used it, but BrowserCommandInput might do the same thing.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-8B9041D5-75CC-4515-B4BB-4CF2CD5BC359#Browser...
ebunn3
@kandennti
That is very cool.  This will work for me just fine.  You're the best!!!
Eric
