Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Import .CATPart via API
1 REPLY 1
Fliegende-Rehe
121 Views, 1 Reply
I have method to import step file into current design, using option class createSTEPImportOptions. Is there any a special or universal class that will allow me upload .CATPart files in the same?
def import_step_geometry(path):
    manager = app.importManager
    options = manager.createSTEPImportOptions(path)
    filename = os.path.basename(path)
    if manager.importToTarget(options, root_comp):
        logger(f'Geometry "{filename}" loaded')
    else:
        raise Exception(f'Cannot load geometry "{filename}"')
Tags (2)
Labels (2)
1 REPLY 1
Hi @Fliegende-Rehe
Apart form native and few neutral formats the file needs to be translated before using it in fusion, so you have to use an upload method to upload the file to the team and use it here is the little script
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        doc: adsk.core.Document = app.activeDocument
        folder: adsk.core.DataFolder = app.data.activeFolder
        uploadFolder = folder.uploadFile(r'C:\Users\somepart.CATPart')
        isUploading = True
        while isUploading:
            if uploadFolder.uploadState == adsk.core.UploadStates.UploadFinished:
                isUploading = False
            elif uploadFolder.uploadState == adsk.core.UploadStates.UploadFailed:
                ui.messageBox('Upload failed.')
                isUploading = False
            adsk.doEvents()
        uploadedFile = uploadFolder.dataFile
        des: adsk.fusion.Design = doc.products.itemByProductType('DesignProductType')
        if doc.isSaved:
           des.rootComponent.occurrences.addByInsert(uploadedFile, adsk.core.Matrix3D.create(), True)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The script will upload the file to active fusion team folder and wait for the upload to complete and once the upload is done then it will insert it into the current document if it is saved.
Boopathi Sivakumar
Senior Technology Consultant
