import a javascripts/ java code in a python script/ print point cloud data
nggarnaud
nggarnaud
Dear all
Happy Saturday. Do you know a way to call/import a JavaScripts/ java code from/in python script?
Secondly how to write a simple point cloud Camera  python/c++/javascript file and print the values of the camera ?
Cheers
Gil
marshaltu
I don't have experiences to call Javascript code in Python script. But I found the answer from the page. Please give a try and have a good luck.
https://stackoverflow.com/questions/10136319/executing-javascript-from-python
Could you please explain a little about your second question? What's mean "point cloud camera"?
Marshal
Marshal Tu
Fusion Developer
nggarnaud
Hello Marshatu
This a link to a point cloud camera video : Raw Depth Data
In my project i am trying to do the same thing using a c code (instead of a JavaScript) and a cheap camera that could replace kinect2 camera. but hte most important thing is a point cloud c code that i could use to implement a Objectarx_point cloud command. And then usein autocad 2015 for mac os x 10.11.6
Thanks a lot, i will check the link.
ekinsb
Fusion 360 doesn't currently support any point cloud capabilities.  In the future you'll be able to draw points using low-level graphics but I'm still not sure that would be the best solution for a point cloud.  Of course the Fusion 360 API doesn't have any support for talking to a Kinect or other devices.  You'll need to use the libraries associated with those devices to interact with them.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
