Message 1 of 1
I made a thing. Export DXF and SAT files for sheet metal parts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here's a happy post for you all 🙂
I've made a script that looks for flat patterns in the file, exports the dxf, if the part has a bend it also exports the SAT file. These are the files that our sheet metal shop use for constructing items.
Have a look, enjoy.
import adsk.core, adsk.fusion, traceback, os, math
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# Prompt the user to select the export folder
folderDialog = ui.createFolderDialog()
folderDialog.title = "Select Export Folder"
folderDialog.initialDirectory = os.path.expanduser("~\\Desktop") # Default to the desktop
# Show the folder dialog and get the selected folder
dialogResult = folderDialog.showDialog()
if dialogResult == adsk.core.DialogResults.DialogOK:
export_folder = folderDialog.folder
else:
# User canceled the folder selection
return
# Get active design
product = app.activeProduct
root_component = adsk.fusion.Component.cast(product.rootComponent)
design_name = root_component.name # Store the design name
# Create a list to store the selected components
selected_components = []
# Create a list to store components missing flat patterns
missing_flat_patterns = []
# Select components that are sheet metal and have flat patterns
component_names = set() # Store component names to avoid counting duplicates
for occ in root_component.allOccurrences:
comp = adsk.fusion.Component.cast(occ.component)
if comp and comp.name not in component_names:
component_names.add(comp.name) # Add the component name to the set
if is_sheet_metal_component(comp):
if not comp.flatPattern:
missing_flat_patterns.append(comp.name)
else:
selected_components.append(comp)
if missing_flat_patterns:
message = "The following components are missing flat patterns and cannot be exported:\n\n"
message += "\n".join(missing_flat_patterns)
ui.messageBox(message)
return
# Create a single exportManager instance
exportMgr = root_component.parentDesign.exportManager
# Export the selected components one by one with a specified format
total_exports = 0
failed_exports = [] # List to store the names of failed files and components
for comp in selected_components:
compName = comp.name
# Specify the full file path for the SAT export
sat_file_path = os.path.join(export_folder, f"{compName}.sat")
# Check if the part has bends
has_bend = has_bend_in_component(comp)
if has_bend:
# Export the component with SAT format
satOptions = exportMgr.createSATExportOptions(sat_file_path, comp)
try:
exportMgr.execute(satOptions)
total_exports += 1
except Exception as e:
failed_exports.append(f"Component: {compName}, Type: SAT")
# Check if a flat pattern exists
if comp.flatPattern:
# Specify the full file path for the DXF export
dxf_file_path = os.path.join(export_folder, f"{compName}_FlatPattern.dxf")
exportMgr = comp.parentDesign.exportManager
dxf_options = exportMgr.createDXFFlatPatternExportOptions(dxf_file_path, comp.flatPattern)
try:
exportMgr.execute(dxf_options)
total_exports += 1
failed_exports.append(f"Component: {compName}, Type: DXF")
else:
# If no bends, export only the DXF
dxf_file_path = os.path.join(export_folder, f"{compName}.dxf")
try:
total_exports += 1
summary_message = f'{total_exports} files exported'
if failed_exports:
summary_message += f'\n\nFailed to export the following files or components:\n'
for failed_export in failed_exports:
summary_message += f"{failed_export}\n"
ui.messageBox(summary_message)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def is_external_component(comp):
# Check if the component is external
return comp.classType() != adsk.fusion.Component.classType()
def is_sheet_metal_component(comp):
# Check if the component is a sheet metal component
is_sheet_metal = False
for body in comp.bRepBodies:
if body.isSheetMetal:
is_sheet_metal = True
break
return is_sheet_metal
def has_bend_in_component(comp):
# Check if the component has a bend
fp = comp.flatPattern
if not fp:
return False # No flat pattern, no bends
topFaceZ = fp.topFace.pointOnFace.z
bendLinesBody = fp.bendLinesBody
if not bendLinesBody:
return False # No bend lines body, no bends
for BRepEdge in bendLinesBody.edges:
# Check if this edge is in the same Z plane as the top face.
# Because of issues with floating point comparisons, it uses a tolerance.
if math.fabs(BRepEdge.pointOnEdge.z - topFaceZ) < 0.00001:
return True
return False
if __name__ == '__main__':
run(None)
-Wall-E
