Announcements
html button event send info to html Palette
JanNavratil
Message 1 of 10
JanNavratil
Hi.
Little tricky question, are we able on button click from HTML pallete use palette.sendInfoToHTML to show some informations from Fusion on pallete? In sample there is on command click to send info to HTML but Im not able to get it working with button clikc on the pallete - it always freez.
  if data['action']=='count':
                    palette = _ui.palettes.itemById('myPalette')
                    palette.sendInfoToHTML('send''test'
Can anyone advice please?
Jan
Replies (9)
Message 2 of 10
goyals
I am not able to understand the problem you are noticing. If possible please share script so We can take a look and try to reproduce the problem on our side. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
Message 3 of 10
JanNavratil
Hi, Im sorry - here is the code
On the html anction - button click I need to get the info from fusion to appear in HTML as text.
# Event handler for the palette HTML event.
class MyHTMLEventHandler(adsk.core.HTMLEventHandler😞
    def __init__(self😞
        super().__init__()
    def notify(selfargs😞
        global _ui, _app, num
        _app = adsk.core.Application.get()
        _ui  = _app.userInterface
        doc = _app.activeDocument
        products = doc.products
        product = products.itemByProductType('CAMProductType')
        _cam = adsk.cam.CAM.cast(product)
        try:
            htmlArgs = adsk.core.HTMLEventArgs.cast(args)
            data = json.loads(htmlArgs.data)
            if data['action']=='verze':
                    if palette :
                        _ui.messageBox(_app.version)
                    if palette :
                        palette.sendInfoToHTML('send', 'value I need to send')
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def run(context😞
    try:
        global _ui, _app
        # Add a command that displays the panel.
        showPaletteCmdDef = _ui.commandDefinitions.itemById('showPalette')
        if not showPaletteCmdDef:
            showPaletteCmdDef = _ui.commandDefinitions.addButtonDefinition('showPalette''Zobrazit CAM CS+ Tools''Show the custom palette''')
            # Connect to Command Created event.
            onCommandCreated = ShowPaletteCommandCreatedHandler()
            showPaletteCmdDef.commandCreated.add(onCommandCreated)
            handlers.append(onCommandCreated)
        # Add the command to the toolbar.
        panel = _ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl = panel.controls.itemById('showPalette')
        if not cntrl:
            panel.controls.addCommand(showPaletteCmdDef)
        # Create and display the palette.
            if not palette:
                palette = _ui.palettes.add('myPalette''Tools''palette.html'TrueTrueTrue300200)
                # Dock the palette to the right side of Fusion window.
                palette.dockingState = adsk.core.PaletteDockingStates.PaletteDockStateRight
                # Add handler to HTMLEvent of the palette.
                onHTMLEvent = MyHTMLEventHandler()
                palette.incomingFromHTML.add(onHTMLEvent)
                handlers.append(onHTMLEvent)
                # Add handler to CloseEvent of the palette.
                onClosed = MyCloseEventHandler()
                palette.closed.add(onClosed)
                handlers.append(onClosed)
            else:
                palette.isVisible = True
    except:
        if _ui:
def stop(context😞
    try:
        # Delete the palette created by this add-in.
        if palette:
            palette.deleteMe()
        # Delete controls and associated command definitions created by this add-ins
        cmd = panel.controls.itemById('showPalette')
        if cmd:
            cmd.deleteMe()
        cmdDef = _ui.commandDefinitions.itemById('showPalette')
        if cmdDef:
            cmdDef.deleteMe()
        cmd = panel.controls.itemById('sendInfoToHTML')
        if cmd:
            cmd.deleteMe()
        cmdDef = _ui.commandDefinitions.itemById('sendInfoToHTML')
        if cmdDef:
            cmdDef.deleteMe()
        #_ui.messageBox('Stop addin')
    except:
        if _ui:
Message 4 of 10
JeromeBriot
First, read the explanations by @marshaltu here: Can't get Javascript add-in to communicate with palette
Next, do not create the palette inside the run function. See there : [bug] Palette created in the run function and Run on Startup enabled
Last, please use the button </> to insert code in your message.
Message 5 of 10
JanNavratil
thank you, Ive checked the post but I did not find reason why I'm getting stucked on the button click with action "count".
class MyHTMLEventHandler(adsk.core.HTMLEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
                    palette = _ui.palettes.itemById('CStool')
                    if palette :
                    if palette:
                        palette.sendInfoToHTML('send', 'test')
        except:
I just need to send data to palette to show some string in <p> from fusion.
But like this, the fusion always get frozen. 😞
Thank you for help !
Jan
Message 6 of 10
JeromeBriot
Can you share the complete add-in (Python & HTML files) ?
Message 7 of 10
JanNavratil
Yes, please find attached files.
many thanks,
Jan
Message 8 of 10
JeromeBriot
Analyze this code:
#Author-JaNa
#Description-CAM Addin as part of Fusion360 CS+
import adsk.core, adsk.fusion, adsk.cam, traceback # pylint: disable=import-error
import json
import threading
# global set of event handlers to keep them referenced for the duration of the command
handlers = []
app = adsk.core.Application.cast(None)
ui = adsk.core.UserInterface.cast(None)
myCustomEventId = 'myCustomEvent'
myCustomEvent = None
stopFlag = None
myThread = None
sendMsgToPalette = False
num = 0
# Event handler for the commandExecuted event.
class ShowPaletteCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            palette = ui.palettes.itemById('CStool')
            if not palette:
                palette = ui.palettes.add('CStool', 'CAM CS+ Tools', 'palette.html', True, True, True, 300, 200)
            else:
        except:
            ui.messageBox('Command executed failed: {}'.format(traceback.format_exc()))
# Event handler for the commandCreated event.
class ShowPaletteCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            command = args.command
            onExecute = ShowPaletteCommandExecuteHandler()
            command.execute.add(onExecute)
            handlers.append(onExecute)
        except:
    def __init__(self):
        super().__init__()
        global sendMsgToPalette
        doc = app.activeDocument
        try:
                if palette :
                    ui.messageBox(app.version)
                sendMsgToPalette = True
        except:
# The event handler that responds to the custom event being fired.
class ThreadEventHandler(adsk.core.CustomEventHandler):
    def __init__(self):
        super().__init__()
        global num
        try:
            if sendMsgToPalette:
                num +=1
                palette.sendInfoToHTML('send', 'test: {}'.format(num))
        except:
            if ui:
class MyThread(threading.Thread):
    def __init__(self, event):
        threading.Thread.__init__(self)
        self.stopped = event
    def run(self):
        while not self.stopped.wait(0.5):
            app.fireCustomEvent(myCustomEventId)
def run(context):
    global app, ui
    global myCustomEvent
    global stopFlag
    global myThread
    ui = None
    try:
        ui  = app.userInterface
        # Register the custom event and connect the handler.
        myCustomEvent = app.registerCustomEvent(myCustomEventId)
        onThreadEvent = ThreadEventHandler()
        myCustomEvent.add(onThreadEvent)
        handlers.append(onThreadEvent)
        # Create a new thread for the other processing.
        stopFlag = threading.Event()
        myThread = MyThread(stopFlag)
        myThread.start()
        showPaletteCmdDef = ui.commandDefinitions.addButtonDefinition('showPalette', 'Zobrazit CAM CS+ Tools', 'Zobrazit CAM CS+ Tools', '')
        panel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
    except:
        if ui:
def stop(context):
    try:
        if handlers.count:
            myCustomEvent.remove(handlers[0])
        stopFlag.set()
        app.unregisterCustomEvent(myCustomEventId)
        if palette:
            palette.deleteMe()
        if cmd:
            cmd.deleteMe()
        cmdDef = ui.commandDefinitions.itemById('showPalette')
        if cmdDef:
            cmdDef.deleteMe()
        #ui.messageBox('Stop addin')
    except:
        if ui:
Message 9 of 10
JanNavratil
Ah cool! thank you, so I have to create new thread for that.
Thank you so much for help !
Jan
Message 10 of 10
JeromeBriot
Yes. You can't use sendInfoToHTML inside MyHTMLEventHandler.
That's what @marshaltu explained (see the link I provided in my first reply).
