Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to visualize the direction of a BRepEdge
1 REPLY 1
jan_weidner
91 Views, 1 Reply
How to visualize the direction of a BRepEdge for debug and learning purposes? I am either looking for an API way to do this or an existing plugin or if there already exists a way to do it in the UI, that would be great.
1 REPLY 1
kandennti
in reply to: jan_weidner
Hi @jan_weidner -San.
It looked like fun, so I created a script.
When you select an edge after running the script, a red cone appears to orient the edge.
The script is attached.
