How to use the Input Changed Event Handler correctly
Apologies if this is a very basic question but I've read lots of forum posts and the API manual and still can't figure this out.
I'm trying to get my script to refresh/update each time the user makes a different selection from a drop-down list. I understand that I need to use the InputChangedEventHandler for this but I'm really struggling with logic and implementation.
Here is a very basic script that I have written to try and get to grips with this functionality. If I can get this example working then I'm sure I can implement this functionality in my actual script.
#Test to understand the InputChanged functionality
import adsk.core, adsk.fusion, adsk.cam, traceback, os #importing modules which contain functions that will need to be used later
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
# Global set of event handlers to keep them referenced for the duration of the command
_handlers = []
# Event handler for the inputChanged event.
class MyInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        eventArgs = adsk.core.InputChangedEventArgs.cast(args)
        userselecteditem = dropdownInput3.selectedItem.index
        changedInput = eventArgs.input
# Event handler for the execute event.
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
        except:
            if _ui:
                _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler for the destroy event.
class MyDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
# Event handler for the commandCreated event.
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
            #--------------------CREATE TABS------------------
            inputs = adsk.core.CommandInputs.cast(eventArgs.command.commandInputs)
            # Create a tab input.
            tabCmdInput1 = inputs.addTabCommandInput('tab_1', 'Selection')
            tab1ChildInputs = tabCmdInput1.children
            # multiple tabs to be created in the future.
            #--------------------CREATE TABLE WITH USER INSTRUCTIONS------------------
            table = tab1ChildInputs.addTableCommandInput('instructionstable', 'Inputs', 1, '1')
            table.minimumVisibleRows = 1
            table.maximumVisibleRows = 3
            table.columnSpacing = 1
            table.rowSpacing = 0
            table.tablePresentationStyle = adsk.core.TablePresentationStyles.itemBorderTablePresentationStyle
            table.hasGrid = False
            textboxInput = inputs.addTextBoxCommandInput('readonly_textBox', 'Text Box 1', '<div align="center">Make your selection below </div>', 2, True)
            textboxInput.isReadOnly = True
            textboxInput.numRows = 3
            table.addCommandInput(textboxInput, 0, 0, False, False)
            #--------------------USER MAKES SELECTION------------------
            dropdownInput3 = tab1ChildInputs.addDropDownCommandInput('dropdown3', '             What is your selection?          ', adsk.core.DropDownStyles.LabeledIconDropDownStyle);
            dropdown3Items = dropdownInput3.listItems
            dropdown3Items.add('1. Item 1', True, '')
            dropdown3Items.add('2. Item 2', False, '')
            dropdown3Items.add('3. Item 3', False, '')
            dropdown3Items.add('4. Item 4', False, '')
            #--------------------CREATE TABLE WSHOWING SELECTION------------------
            table = tab1ChildInputs.addTableCommandInput('selectiontable', 'Inputs', 1, '1')
            table.minimumVisibleRows = 3
            table.rowSpacing = 10
            textboxInput = inputs.addTextBoxCommandInput('readonly_textBox', 'Text Box 1', 'your selection is '+str(userselecteditem), 2, True)
            #-----------Subscribe to the various command events-------------
            # Connect to command execute.
            onExecute = MyExecuteHandler()
            eventArgs.command.execute.add(onExecute)
            _handlers.append(onExecute)
            # Connect to input changed.
            onInputChanged = MyInputChangedHandler()
            eventArgs.command.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            # Connect to the command terminate.
            onDestroy = MyDestroyHandler()
            eventArgs.command.destroy.add(onDestroy)
            _handlers.append(onDestroy)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui  = _app.userInterface
        # Create a command.
        cmd = _ui.commandDefinitions.itemById('tableTest')
        if cmd:
            cmd.deleteMe()
        cmd = _ui.commandDefinitions.addButtonDefinition('tableTest', 'User selection test', 'Table Test', '')
        # Connect to the command create event.
        onCommandCreated = MyCommandCreatedHandler()
        cmd.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        # Execute the command.
        cmd.execute()
        # Set this so the script continues to run.
        adsk.autoTerminate(False)
    except:
        if _ui:
The script should just tell the user what selection they have made from the drop-down list. Apologies for tagging members but @ekinsb I'm sure this would be very easy for you to solve.
Thanks in advance.
  • API
BrianEkins
Here's a modified version of your script.  I fixed some small issues.  I also made the command inputs global variables.  This isn't required because you can get later at any time from the command object but it saves having to get them again and again.  I then use them in the input changed event.
_handlers = []
_instructionTable = adsk.core.SelectionCommandInput.cast(None)
_dropdownInput3 = adsk.core.DropDownCommandInput.cast(None)
_selectionTable = adsk.core.SelectionCommandInput.cast(None)
_textBoxInput1 = adsk.core.TextBoxCommandInput.cast(None)
_textBoxInput2 = adsk.core.TextBoxCommandInput.cast(None)
    def __init__(self):
        super().__init__()
        try:
            if changedInput.id == 'dropdown3':
                _textBoxInput2.text = 'Your selection is ' + _dropdownInput3.selectedItem.name
        except:
            if _ui:
    def __init__(self):
        super().__init__()
        try:
        except:
            if _ui:
    def __init__(self):
        super().__init__()
        adsk.terminate()
    def __init__(self):
        super().__init__()
        try:
            global _instructionTable
            _instructionTable = tab1ChildInputs.addTableCommandInput('instructionstable', 'Inputs', 1, '1')
            _instructionTable.minimumVisibleRows = 1
            _instructionTable.maximumVisibleRows = 3
            _instructionTable.columnSpacing = 1
            _instructionTable.rowSpacing = 0
            _instructionTable.tablePresentationStyle = adsk.core.TablePresentationStyles.itemBorderTablePresentationStyle
            _instructionTable.hasGrid = False
            global _textboxInput1
            _textboxInput1 = inputs.addTextBoxCommandInput('readonly_textBox', 'Text Box 1', '<div align="center">Make your selection below </div>', 2, True)
            _textboxInput1.isReadOnly = True
            _textboxInput1.numRows = 3
            _instructionTable.addCommandInput(_textboxInput1, 0, 0, False, False)
            global _dropdownInput3
            _dropdownInput3 = tab1ChildInputs.addDropDownCommandInput('dropdown3', '             What is your selection?          ', adsk.core.DropDownStyles.LabeledIconDropDownStyle)
            _dropdownInput3.listItems.add('Item 1', True, '')
            _dropdownInput3.listItems.add('Item 2', False, '')
            _dropdownInput3.listItems.add('Item 3', False, '')
            _dropdownInput3.listItems.add('Item 4', False, '')
            global _selectionTable
            _selectionTable = tab1ChildInputs.addTableCommandInput('selectiontable', 'Inputs', 1, '1')
            _selectionTable.minimumVisibleRows = 3
            _selectionTable.maximumVisibleRows = 3
            _selectionTable.columnSpacing = 1
            _selectionTable.rowSpacing = 10
            _selectionTable.tablePresentationStyle = adsk.core.TablePresentationStyles.itemBorderTablePresentationStyle
            _selectionTable.hasGrid = False
            global _textBoxInput2
            selectedItem = _dropdownInput3.selectedItem.name
            _textBoxInput2 = inputs.addTextBoxCommandInput('result_textBox', 'Text Box 2', 'Your selection is ' + selectedItem, 2, True)
            _textBoxInput2.isReadOnly = True
            _textBoxInput2.numRows = 3
            _selectionTable.addCommandInput(_textBoxInput2, 0, 0, False, False)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        # Create a command.
        if cmd:
            cmd.deleteMe()
        cmd.execute()
    except:
        if _ui:
Brian Ekins
Thanks so much for this Brian, this has helped me immensely!
