Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to use sketch mode?
3 REPLIES 3
obatake5TC3R
1818 Views, 3 Replies
Is there an API to enter or exit sketch mode?
Sample programs will be appreciated.
3 REPLIES 3
goyals
in reply to: obatake5TC3R
PFA script showing how to create sketch lines. In similar way you can create other geometries. You can get the more details at this page http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-91E892FC-BE5D-4AAB-A823-61BFF7A7B663.
Shyam Goyal
Sr. Software Dev. Manager
obatake5TC3R
in reply to: goyals
The method of question seemed to be bad.
I'd like to know the API to enter sketch edit mode, and the to exit sketch edit mode.
I want to enter in sketch edit mode. Becouse I want to create a command in sketch edit mode.
goyals
I am afraid to say that there is no way you can customize Sketch palette through Fusion API. Definitely you can add new command to sketch command dropdown but not in to sketch palette.
Shyam Goyal
