Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
how to use MultiLineTextDefinition.rectangleLines ?
2 REPLIES 2
lionel.courgnaud
74 Views, 2 Replies
Hello
I've got a multiline text set like this. variables are not important.
        textInput.setAsMultiLine(cornerPoint,
                                 diagonalPoint,
                                 horizontalAlignment,
                                 verticalAlignment,
                                 characterSpacing)
        textInput.isHorizontalFlip = False
        textInput.isVerticalFlip = False
        textInput.fontName = 'Arial'
        myTextc1 = texts.add(textInput)
I need to constraint the bottom of the bounding box of this text to a sketchline (skLine1). It Seems I can access bounding box through MultiLineTextDefinition.rectangleLines, but I don't know how.
If it's easier, I could constraint one of the point (from bounding box) to a sketch point (skPt1).
Any example ? thank for your precious help.
2 REPLIES 2
Hi @lionel.courgnaud -San.
Check the type of the rectangleLines property.
    print(type(myTextc1.definition.rectangleLines))
The output will look like this.
<class 'adsk.fusion.SketchLineVector'>
In the case of the Fusion360 API, anything that is a ~Vector can be cast as a List.
    rectangleLines = list(myTextc1.definition.rectangleLines)
After that, you should be able to handle it as a normal SketchLine.
It is also possible to handle it directly without casting it to a list.
    line = myTextc1.definition.rectangleLines[0]
thanks.
this helped me 🙂
