Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to use manipulators as in the insert canvas dialog
1 REPLY 1
philipp.stein
157 Views, 1 Reply
Hey,
I would like to use Manipulators in my add-in,  similar to them used in the insert canvas dialog:
I only found the AngleValueCommandInput and the DistanceValueCommandInput so far. Is there a way to also use the scaling manipulators, or the free move manipulator with the API?
Thanks for your help
Philipp
1 REPLY 1
BrianEkins
in reply to: philipp.stein
Unfortunately, the command inputs you mentioned are the only inputs currently available in the API that have graphic manipulators. I know a command input that lets you manipulate a coordinate system in various ways (move, rotate, and scale) would be very useful and hopefully, we'll see it in the future.
Brian Ekins
