Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
how to use groupCommands ?
3 REPLIES 3
mohammadkhader698
112 Views, 3 Replies
I need to make userInterface to get Inputs from the  user then modify the design so I decide to use groupCommad but the problem is I cant understand the parameters for groupCommad  and  I don't know how to use it
3 REPLIES 3
Hi @mohammadkhader698 .
We made a simple sample.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
_app: adsk.core.Application = None
_ui: adsk.core.UserInterface = None
_handlers = []
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandCreatedEventArgs):
        adsk.core.Application.get().log(args.firingEvent.name)
        try:
            global _handlers
            cmd: adsk.core.Command = adsk.core.Command.cast(args.command)
            inputs: adsk.core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            inputs.addTextBoxCommandInput(
                'txtOutIpt',
                'text',
                'Outside',
                1,
                True
            # https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-38a0b5b9-9339-4c4e-b113-130877c99497
            grpIpt: adsk.core.GroupCommandInput = inputs.addGroupCommandInput(
                'grpIptId',
                'Group Input Test'
            grpChildIpts: adsk.core.CommandInputs = grpIpt.children
            grpChildIpts.addTextBoxCommandInput(
                'txtInIpt',
                'text',
                'Inside',
                1,
                True
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandEventArgs):
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef: adsk.core.CommandDefinition = _ui.commandDefinitions.itemById(
            'test_cmd'
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                'test_cmd',
                'Test',
                'Test'
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
thank you @kandennti  but honestly I don't know how to make command input , so what I need is to make script that get inputs from user then modify an exist design ,I have already a parametric design so I thought just I need the inputs from the user  so what is the best way to do the script
hi @mohammadkhader698
What you want require two parts:
1. To add the user interface to prompt for the information that is required.  This is done with the COMMANDS, which are the user interface controls in Fusion360.  Here you have a good example with many options: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-e5c4dbe8-ee48-11e4-9823-f8b156d7cd97
2. Since you have a parametric design, then you need to update the values of your parameters with the user input.
Here you have an example of how to update a parameter value by code: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-33127518-f20a-11e5-bab1-a0a8cd5c2c67
Hope this two examples help you in the implementation.
Keeping the API Reference Manual open while you develop is very handy.
Jorge
