How to turn a revolute joint in a C++ script
RogerInHawaii
RogerInHawaii
I've got a a joint that I've picked up from a JointsList...
Ptr<Joint> ThisJoint = JointsList->item(0);
and I do know that it's a revolute joint, although I only know that because I also check the NAME that I gave to it. So my first question is how can I determine the actual "type" of joint from my ThisJoint object.
But more importantly, once I have hold of the revolute joint,how do I, using a C++ script, cause the joint to actually rotate? What method do I call? And do I have to call something extra in order to get the image to update so I can actually SEE the rotation occurring?
-> see Learning page  RevoluteJointMotion API Sample
Here is some condensed code with the key points:
Ptr<RevoluteJointMotion> motion = joint->jointMotion();
// jointMotion() is property of Joint
// RevoluteJointMotion is a derived class from JointMotion
JointTypes type = motion->jointType();
// JointTypes => ENUM for type => if you just want to find out the type (first part of your question)
bool isOk = motion->rotationValue(1.57);	// change angle
