Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to take pictures of the different faces of a cube on Fusion 360 (using an Add-in or a Script)
3 REPLIES 3
146 Views, 3 Replies
I am really new with Fusion 360 and I would like to create an Add-in or a Script that would allow me to take pictures of the different faces of a 3D object and save them. I've made something that seems like it could work, but Visual studio keep telling me that I can't use the command AppearanceCapture and AppearanceCaptureOptions. While later I would like to make a program that could work with any 3D shape, for now I simply want to be able to get pictures of the different faces of a cube (baby steps).
Could any one of you help me with my problem or give me idea on how I could do this?
Linked to this post is the code I've made.
Thank you in advance!
3 REPLIES 3
Jorge_Jaramillo
in reply to: 201933238
I wrote the following function to capture images of different views (you can call it from script's run() function):
def save_view_images():
    WIDTH = 400
    HEIGHT = 300
    app = adsk.core.Application.get()
    des: adsk.fusion.Design = adsk.fusion.Design.cast(app.activeProduct)
    for nv in des.namedViews:
        nv.apply()
        app.activeViewport.saveAsImageFile(f'/99tmp/views/{nv.name}.png', WIDTH, HEIGHT)
It reads the custom views you have defined in the current design:
And save an image of every view. This is the result:
I hope this could help you out.
Jorge Jaramillo
Software Engineer
in reply to: Jorge_Jaramillo
Thank you very much for helping me with this matter. The solution you gave me is miles beyond what I was originally thinking of doing.
I added your solution to a new fusion 360 script however it doesn't seem to be working (the fault is most likely that I forgot to add something).
When I try to run the script I am met with this :
Again, I am certain the problem is linked to the fact that I forgot something. Could you help me understand what I am missing please.
A student who is interested in learning python
Jorge_Jaramillo
Hi @201933238 ,
The Design.namedViews property is new in September-2023 updated version:
Make sure you have the latest Fusion 360 update and it will run without errors.
I'm running on this version:  app.version='2.0.17244'
Jorge Jaramillo
Software Engineer
