Announcements
How to set: Advanced swarf - Geometry - Avoid machine surfaces - Model, clereance
maurizio_manzi
maurizio_manzi
How to set the parameter 'clereance' of 'Advanced swarf - Geometry - Avoid machine surfaces - Model' (see pic)?
Best regards
Maurizio
kandennti
Hi @maurizio_manzi -San.
I think the parameter name displayed there is wrong.
The correct parameter name seems to be "clearanceInfo".
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.CAM = app.activeProduct
        unitsMgr: core.UnitsManager = camObj.unitsManager
        setup: cam.Setup = camObj.setups[0]
        opeAdvancedSwarf: cam.Operation = setup.operations[0]
        param: cam.CAMParameter = opeAdvancedSwarf.parameters.itemByName(
            "clearanceInfo"
        ui.messageBox(f"{unitsMgr.formatValue(param.value.value)}")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
maurizio_manzi
'operation1' is my advanced swarf operation reference.
I test:
cadcontours1: adsk.cam.CadObjectParameterValue = operation1.parameters.itemByName('clearanceInfo').value
cadcontours1.value = -0.1
But it is also not working (see pic). The value remain 0.
Best regards
Maurizio
kandennti
kandennti
I did some more research.
The "clearanceInfo" was a parameter for "Total Clearance".
I right-clicked on the operation and opened "Compare and Edit" and could not find the corresponding parameter, so I think it is not provided by the API.
maurizio_manzi
okay, thank you. I will make a future-request in the Manufacturing (CAM) API Feedback post.
