Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to select the geometry for 'contour2d'- operation
3 REPLIES 3
maurizio_manzi
223 Views, 3 Replies
for pocket2d I select the geometry:
operationInput = setup.operations.createInput('pocket2d')
operationInput.tool = tool
op_2Dpocket = setup.operations.add(operationInput)
cadcontours = op_2Dpocket.parameters.itemByName('pockets').value
selection = cadcontours.getCurveSelections()
Geometry = [mySketch.sketchCurves.item(0)]
chain = selection.createNewChainSelection() # Use chain selection
chain.inputGeometry = Geometry
cadcontours.applyCurveSelections(selection) # The default is closed chain,so just apply the chain.
How to select the geometry for 'contour2d'- operations ?
cadcontours = op_2Dpocket.parameters.itemByName('pockets').value # <--- 'pockets' is not allowed for contour2d.
Where can I find a list of these "names" in the API help? These are not parameters and are not displayed in the cam with the shift key.
Best regards
Maurizio
3 REPLIES 3
BrianEkins
in reply to: maurizio_manzi
How the geometry is defined is described in this article in the API help.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A08218F6-3885-4677-9CAD-7234BCEE85CC#CadCont...
Brian Ekins
kandennti
Hi @maurizio_manzi .
I sometimes have trouble displaying the parameter name with the shift key once, but it appears after a few times.
maurizio_manzi
in reply to: kandennti
Thank you very much.
Best regards
Maurizio
