Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to select a rigid group?
2 REPLIES 2
ricardoxcm
402 Views, 2 Replies
Hello!
I've been working on a short script to select a rigid group and print its name. However, I've only been able to select a component and print its name so far. Is it possible to determine to which rigid group a component belongs to and print the rigid group's name? Or is there a more direct way to do it?
Thanks a lot for the help,
Ricardo
import adsk.core, adsk.fusion, traceback
app = adsk.core.Application.cast(None)
ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global app, ui
        app = adsk.core.Application.get()
        ui = app.userInterface
# Select a Body.
        ui.messageBox("Please select the root link.")
        rootSel = ui.selectEntity('Select root', 'Bodies')
        if rootSel:
            root = adsk.fusion.BRepBody.cast(rootSel.entity)
            toprint = root.parentComponent.name
            print('Selected body :', toprint)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
2 REPLIES 2
ekinsb
in reply to: ricardoxcm
Rigid groups are only selectable in the user-interface from within the browser.  However, you can select other types of entities, like you were trying to do, and then get any associated rigid groups from them.  Rigid groups are applied to occurrences to it's easiest to get them from them and they are selectable in the graphics window.  I modified your code to do this.
def run(context):
    try:
        global app, ui
           # Select an occurrence.
        occSel = ui.selectEntity('Select occurrence', 'Occurrences')
        if occSel:
            occ = adsk.fusion.Occurrence.cast(occSel.entity)
            result = ''
            for rigidGroup in occ.rigidGroups:
                result += '\n    ' + rigidGroup.name
            if result == '':
                ui.messageBox('No rigid groups for the selected occurrence.')
            else:
                ui.messageBox('The rigid groups below are on the selected occurrence:' + result)
    except:
        if ui:
Brian Ekins
Mod the Machine blog
ricardoxcm
in reply to: ekinsb
Thanks a lot for the quick reply! It worked perfectly.
